Fuel Canister Question..
Old Apr 14, 2012 | 06:14 PM
Ride Da Fire's Avatar
Default Fuel Canister Question..
I bought a 1995 GSR 4drs shell from a car shop last year and I have been working on it since then try to get ready for engine swap. I bought a JDM 97 GSR from H-Motor and now it's ready to be drop in the car but came to find out that the car doesn't have a fuel canister. I'm about to order a fuel canister from Del-Ray Acura but I don't know how is this going to work out. The car is 95 and the engine is 97, so which fuel canister should I order? 95 or 97? Any input would be appreciated, thanks in advance.
Thank you.
Old Apr 14, 2012 | 08:28 PM
virgineg6's Avatar
Default Re: Fuel Canister Question..
Do you mean fuel filter?
Old Apr 14, 2012 | 08:49 PM
Old Apr 14, 2012 | 10:24 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Dont matter. The both work. I am using the one of my 94 VX for my GSR.
Old Apr 15, 2012 | 05:54 PM
Thank you.
Old Apr 15, 2012 | 06:10 PM
fcm's Avatar
fcm
Old Fart
Although the part numbers are different, I also think either one will work, I would get the 95, then you know for sure it will fit
Old Apr 16, 2012 | 06:04 AM
g_steelo99's Avatar
Both will work i have a 96 engine on my 2b000 gsr and im using the 2000 one on my car
Old Apr 16, 2012 | 07:12 AM
TheRealTegger's Avatar
Thank you.
The '95 and '97 canisters are DIFFERENT. They are NOT compatible.
'95 was the last year for OBD-I, where the canister has only a simple vacuum-diaphragm.
'96-and-up are OBD-II canisters. They have an electrical canister-shut solenoid that the OBD-I canisters lack.
You should be using the canister that is compatible with whatever ECM and harness you are using: If the ECM/harness are '95 or earlier, use the '95's canister; if the ECM/harness are '96+, use a '96+ canister.
Old Apr 16, 2012 | 07:34 AM
hbcrazy88's Avatar
your correct if they are talking about the charcoal canister, everyone says hes talking about the fuel filter so i dont know.
if its they filter.... any year should work but if your talking about the canister, yea they are different.
Old Apr 16, 2012 | 08:40 AM
RideDaFire posted an image with the relevant part circled in red. That part is the EVAP canister.
Old Apr 17, 2012 | 07:00 PM
I'm running an OBD1 engine harness, so I'm going to order a 94 -95 canister from del-ray acura.com soon.
thanks all for your help, I really appreciated it.
thank you.
Old Apr 18, 2012 | 03:15 AM
IN VTEC's Avatar
It's pretty expensive. I have one I can give you from my '95 GS-R. I can't use it anymore since I'm using the EVAP purge output to actuate the boost solenoid.
Old Apr 18, 2012 | 05:03 AM
These canisters last forever.
If I were you, I'd find a wrecking yard ("auto recycler") which has that generation of Integra, and pull the canister from that. Used will be a LOT cheaper than new!
The yard will also know about interchangeability. You may even be able to use a '90-'93 canister. I don't know, but they will.
donvito#1
May 14, 2008 04:21 PM
renegadez7o7
Sep 14, 2007 11:12 PM
PartsChic
Aug 10, 2005 05:09 PM
