D series blowout
Old Apr 14, 2012 | 01:29 PM
Mikes2000civicsi's Avatar
Default D series blowout
Hey hondatech,
Moved on to the b series world so here are quality d series parts for cheap
All parts are best offer so
Driver side and passenger side axles(d series)-20 each
D series log style turbo manifold(t25 greddy)-50
Distributor(obd2)-50
jspec stage 3 clutch-125
1 d16z6 vtec head(solenoid,no valve cover-sold
1 D16y8 vtec head(solenoid,no valve cover)-sold
1 B20 block(with pistons and main caps,crank)-100
1 93 lx transmission-SOLD
D series shift linkage-25
d16z6 block(everything assembled)-75
Arp Head Studs(d series)-sold
Cool Copper color D series valve cover-25
1 disco potato turbo(need rebuild)-75
1 99 civic ex wing-20
1 tapped d series oil pan for turbo-SOLD
Steelies!!(14 and 13)
i'm sure i'm forgetting some stuff
msg me or text me at 848 525 3283
Old Apr 15, 2012 | 12:54 PM
Default Re: D series blowout
bump for cheeeaaap parts,
Old Apr 17, 2012 | 07:10 AM
radicaled434's Avatar
-Skunk2 Pro Series Coilovers and Struts - $400
(Fronts and Rears)
-99 Si Gauge Cluster - $170
-Front & Rear Seats - $175
(From 98 EX)
-Auto Gauge Cluster with Tach - $100
(Comes with S7 Gauges)
-99-00 Front End - $100
(Green Hood Dented, Primed Bumper Cracked)
-Catback Exhaust -$80 (Stock welded, no flange at cat) -14" Steelie - $20
(Comes With Tire, 15% Tred)
(4 Available)
-13" Steelie - Sold
-Headlight Housings - Sold
-Clutch Master Cylinder - $20
-Clutch Slave Cylinder - $20
-40/40 Prop Valve - Sold
(Off of a 99 Civic Si)
-Passenger Side Spindle/Knuckle - $60
(Includes Caliper, Rotor and Upper Control Arm)
-14mm Rear Sway Bar- $30
(Doesn't Come With Mounting Brackets)
-14" Slim Fan- $30
-Radiator Support- $50
-Total Audio 6x9 - $40
-7/8 Master Cylinder and Brake Booster - $50
-Passenger Side Motor Mount - $25
-Rear Motor Mount - $25
-96-98 JDM Grill - $10
-Copper V-Tec Valve Cover - $30
(D-Series)
-Pioneer DEH-p4700mp and IPod Aux plug - $60
-Fusebox - $35
(Under Hood and Under Dash)
-B-Series CX Racing Radiator - $50
-99-00 Tail Lights - $XX
(Will Trade For 96-98 Tail Lights)
-B18B1 LS Engine with Trans - Sold
-Rear Disc Brake Conversion - Sold
Anything else needed just ask
Txt/Call
609-540-1831
Old Apr 18, 2012 | 07:44 PM
bump for duel sellers
Old Apr 18, 2012 | 09:41 PM
RedHatch00's Avatar
where in nj r u located interested in the z6 head
Old Apr 22, 2012 | 09:28 AM
bump for updated list
AlfieRoach
Jul 7, 2011 03:19 PM
jdmshawn95
Dec 12, 2010 07:38 PM
hatchbackjo01
Jan 1, 2009 07:10 PM
JDM_EK4_Coupe
Apr 15, 2007 07:50 PM
