2000 integra LS auto 20mpg city driving
Old Apr 14, 2012 | 12:28 AM
raverx3m's Avatar
Default 2000 integra LS auto 20mpg city driving
just finished doing the maintenance on it and it is still getting crappy gas mileage.
car has 134k miles original everything
auto tranny stock size wheels
replaced new:
radiator and all hoses
new honda thermostat
new coolant
new oil and tranny fluid
new cap rotor wires and spark plugs
both O2 sensors are functioning properly
timing is set to OEM specs
compression is 180 all 4 cylinders
no oil or coolant leaks
engine runs very good and accelerates good also
car is completely stock
no codes
no drag on brakes
i used heat rating 6 plugs with smaller gap as was suggested in one of the threads here to make up for added ethanol in gas. but it didnt change anything
is there something that im missing here?
whats the typical gas mileage of auto LS anyway?
Old Apr 14, 2012 | 08:45 AM
JustDoingMe's Avatar
Default Re: 2000 integra LS auto 20mpg city driving
Dirty air filter?
Old Apr 14, 2012 | 01:00 PM
raverx3m's Avatar
Didnt look like but i guess i might as well replace it.
Old Apr 14, 2012 | 08:38 PM
virgineg6's Avatar
Fuel filter? Have you tried seafoaming.
Old Apr 14, 2012 | 09:01 PM
racebum's Avatar
fuel and air filters
your o2 is highly suspect. all it takes is a small change in voltage to make the car run really rich. normally this will trigger a CEL. a plugged cat can also kill mpg
Old Apr 14, 2012 | 09:10 PM
el crapitan's Avatar
check the ect sensor resistance. first cold, then hot. see if it falls within spec
also, may sound silly, but check your tire pressure.
Old Apr 14, 2012 | 09:56 PM
raverx3m's Avatar
tires are good.
new fuel filter( forgot to add) i did do seafoam as well. and the engine has alost zero sludge its golden like it supposed to be
only thing i didnt do is check valve clearance.
well heres both O2 sensor readings looked normal to me
Old Apr 15, 2012 | 10:56 AM
safedriver's Avatar
My 2000 LS w/auto gets 29 mpg city and 34 hwy. It has 106xxx miles on it.
Last year my mileage dropped, when my cat went bad, but I did not get a check engine light. I ran with a test pipe for a couple weeks and my mpg went back up.
I bought a used OEM cat and installed it. I am back to my normal mpg 29 - 34.
Old Apr 15, 2012 | 11:10 AM
racebum's Avatar
looks good to me too, i'm with safe for your next task. the B series in general tends to run rich and burn anywhere from a little oil to a lot of oil. years back i pulled a melted one off a stock gsr with 150k miles.
might be worth pulling yours for the sunshine test {aiming cat at sun and looking through it}
JDM215
Nov 30, 2010 03:51 AM
092eg6
Sep 6, 2009 07:56 PM
julioboostamante
Jun 25, 2008 02:38 PM
jdadams12
Feb 22, 2007 09:24 AM
newhondaowner29
Nov 18, 2004 10:45 AM
