Tien Basic Coilovers - pop sound
If this is the case it could be that the spring becomes unloaded and clunks about. If this is the case you can remedy this problem using coilover helper springs.
So with your suspension unloaded the main spring can do this...
You will need to add a helper spring such as these...
Then your coilovers will look like this...
I have a similar problem with my 98 accord V6....except that I've already replaced the following...
Strut rod bushings, upper and lower control arms and ball joints, sway bar links, rack and pinion, outer tie rods and all 4 struts. It WAS worse before all that but its still there.
I hear a clunk or knock when turning , on bumps, nothing really consistent.
Happens on minor dips in the road.
Sway bar bushings were inspected, found to be fine and lubricated. Did not help.
Let me get the car on a lift and check it out. Thanks for the feedback.
Its possible you have a defective part. I had a strut that had a leaky o ring and it would creak just as you describe it.
RedlineMotive
Jun 18, 2012 09:23 AM
