Steelies Tire Size
Old Apr 12, 2012 | 08:59 PM
MDM's Avatar
MDM
Default Steelies Tire Size
Hello All, I was wondering whats the biggest tire size i can put on my stock 14" steelies. Its for my 98 Civic Sedan (DD)
TIA
Old Apr 12, 2012 | 10:09 PM
AdamEG's Avatar
Default Re: Steelies Tire Size
Look on the b pillar inside your drivers door, should be a sticker stating tire size most likely 185/65R14, any variance to that will change speedometer reading google miata tire size calculator and use that to see how off your speedometer will be with diff size tires
Old Apr 12, 2012 | 10:19 PM
MDM's Avatar
MDM
well, i believe that sticker is long gone, but ill keep searching, thanks for the info
Old Apr 13, 2012 | 04:15 AM
redm3turbo's Avatar
175/185/195 all will fit -- 205 would be pushing it.
side walls can be 60/65/70 and 75 would be pushing it.
So any combo of above.
I run 185/70/14 on occasion for the more sidewall, rides a bit better. As for speedo being off with those small differences, your looking at maybe 1-2 mph off. not anything you'd notice really.
Old Apr 13, 2012 | 06:57 AM
toyomatt84's Avatar
Sanji
195/65/14 is the largest safe size you can run on those wheels. The 185/70/14's are just above safe limits (at about 3.02% oversized).
Old Apr 13, 2012 | 09:18 AM
MDM's Avatar
MDM
thanks guys! now, where can i find the diagram where it shows you the numbern and the place on the tire. for example, 14 is the size of the rim, 65 is the width of the tire and 195 is the height, right?
Old Apr 13, 2012 | 09:26 AM
MDM's Avatar
MDM
nevermind, found it. stupid question. toyomatt, why will 185/70/14 be pushing it, if 195/65/14 has a bigger width?
Old Apr 13, 2012 | 10:16 AM
TunerN00b's Avatar
Diameter.
You want to preserve the original tire diameter, even if you change wheel and/or tire width.
Old Apr 13, 2012 | 11:28 AM
doc@tirerack's Avatar
195/60R14 and 195/65R14 need at least a 5.5" wide wheel, and our records indicate stock wheel was 14x5.
Old Apr 13, 2012 | 12:09 PM
MDM's Avatar
MDM
got it. thanks guys
91da_teg
Feb 7, 2009 05:47 AM
civics4lyfe
Jan 27, 2009 08:09 AM
OldSchoolHatch
Feb 17, 2007 02:39 PM
96Sedan
Mar 1, 2006 04:15 PM
quickda6
Jun 6, 2003 03:21 PM
