Garage Sale **No Reasonable Offer Refused**
Hey guys, going to be moving soon and I went through the garage and made a list of some of the stuff I have for sale. Not really looking for any trades, unless you have any S2000 parts. All parts are located in Hesperia, Ca. I can ship if needed. Like I said, no REASONABLE offer refused (this is why I have not posted prices). Since there are so many parts, I CAN send picks via email if requested. Thanks.
**MISC Garage Stuff:
-Autometer Phantom Water temp 2 5/8” BNIB part # 5831
-APC oil pressure gauge BNIB part # 107163
-15” 5 star wheels set of 4 powdercoated black 4 lug universal (good for dummies, 1 wheel is cracked)
-16” TSW trophies 4 X 114.3
-Scorpion 40” creeper w/ tool trays and folding mechanics seat BNIB part # CRS-40
-Powerbuilt 44” Rolling work table BNIB
-Craftsman Rolling tool carrier (good for hauling tools at the junkyard)
-Antique Sears Single Stage Oxy Acetylene welding and cutting outfit BNIB Part # 95443
Honda Parts:
**92-95 Civic and B Series into EG parts:
-B series to EG shifter w/ dual bend short shifter
-OBD 1 B series B16 VTEC harness for EG (VTEC solenoid wire cut off)
-Red B series INJEN CAI (needs a repair, has a hole)
-BNIB autometer dual gauge pod 2/3dr part# 20410
-EG Clock
-EG OEM radiator (used)
-EG/DC RSR lowering springs approx 1.5” drop
-Honda CD player w/ code (from a 99 civic)
-Blue EG 4dr power mirrors
-EG SRS steering wheel wiring
-EG black driver airbag
-EG Clear Corners 2/3 dr
-Black EG coupe rear speaker covers
-EG coupe and sedan axel back exhaust Maxspeed brand
-1 full set of B series to EG mounts OEM
-EG D series “t” bracket
-3 sets of BNIB Accel Plug wires for D series non vtec part #7913Y
-OBD 1 PO6 ecu
**94-01 Integra:
-Silver AEM B series fuel rail (just rail)
-AEM Blue adjustable cam gears
-Blue Battery tie down (APC) brand
-B16 DOHC VTEC valve cover (good condition, a few nicks but no peeling) SOLD
-B Series timing belt covers (1 set)
-B series upper outer timing belt cover
-GSR oil pan OEM, some dents
-2 B series flywheel inspection plate covers
-OEM GSR timing belt (used)
-OEM GSR oil pump (used)
-BNIB LS B series ACCEL plug wires 8mm part number 7911Y
-2 LS distributors not working, one has the leg cut for vtec head. # TD 55U
-OBD 1 P75 ecu
-OBD 1 LS valve cover
-OBD 1 OEM B series cam gears
-94-96 Tan DC steering wheel airbag
-94-95 SRS unit
-94-97 DC turn signals
-DC cluster trim
- Many B Series Axels (some need boots)
-1 B series half shaft
**90-93 Integra:
-DA cluster trim (2 broken tabs on the driver air vent)
-OBD 0 PR3
-OBD 0 PR4 ecu
-2 OBD 0 DA engine harnesses (one of them is missing the knock sensor)
-VSS for Cable B Trans
-Many B Series Axels (some need boots)
**88-91 Civic
-B series to EF adjustable shift linkage with short shifter
-2 B series to EF “t” brackets
Honda Parts:
-EG Clock
-OBD 1 PO6 ecu
**94-01 Integra:
-OBD 1 P75 ecu
-94-95 SRS unit
-DC cluster trim
**90-93 Integra:
-OBD 0 PR3
-OBD 0 PR4 ecu
**88-91 Civic
sohcturbo92vx, does 25 shipped sound good?
ccbb34, can do 60 shipped on the valve cover.
SickEr1, I emailed you, fyi your H-T inbox is full...
All pm's replied.
All pm's replied.
