vtech head d16y8 to D15B1 will it fit?
Old Apr 12, 2012 | 07:22 PM
Tazmania_boy's Avatar
Default vtech head d16y8 to D15B1 will it fit?
Looking to buy the vtec head d16y8 with intake manifold to do a swap but im not sure, will it fit and what else do i need. thanks.
Old Apr 12, 2012 | 07:34 PM
KINGVEM^^ED6's Avatar
Default Re: vtech head d16y8 to D15B1 will it fit?
Vtech head wont fit since they make home phones
A vtec head will work after you convert to mpfi and.obd1 and wire up vtec
Old Apr 12, 2012 | 07:39 PM
Lols ... thanks for the reply
Old Apr 12, 2012 | 07:45 PM
You can buy this harnessss
Get a p28 ecu and you'll be straight
http://hondamarketplace.com/showthread.php?t=2993207
Old Apr 12, 2012 | 07:51 PM
cool appreciate the info that helps alot...
Old Apr 18, 2012 | 05:33 PM
Just want to share how much its gonna cost me to do a minime vtec swap.
So Newbee like me have an idea if its worth boosting up some power on a D15B1 engine.
1991 EF HATCH D15B1 TO D16Y8 HEAD SWAP DPFI TO MPFI
PARTS PRICE
1. D16Y8 COMPLETE HEAD AND INTAKE MANIFOLD WITH SENSORS $180
2. THROTTLE BODY WITH SENSOR S $60
3. D16Z6 DISTRIBUTOR $80
4. D16Z6 P28 ECU CHIPPED $125
5. OBD0 TO OBD1 ECU JUMPER HARNESS $50
6. OBD0 TO OBD1 DIZZY HARNESS $40
7. D16Y8 HEAD GASKET $55
8. D16Y8 TIMING BELT $27
9. INJECTOR RESISTOR BOX $22
10. 1992 -1995 HONDA CIVIC FUEL INJECTORS PLUGS WIRES $25
11. MECHANIC $300
TOTAL $964
Old Apr 18, 2012 | 08:08 PM
t-town_ep's Avatar
you can save yourself money by doing it yourself, its not all that hard. there have been lots of write ups that are very helpful.
Old Apr 18, 2012 | 08:30 PM
Don't need a resistor box if using obd1 injectors
Some of those prices are
Old Apr 18, 2012 | 11:26 PM
Arthas's Avatar
"Mechanic" hahahahaha fck that **** do it yourself its easy as fuqq.
I can give you that injector box for $10 shipped.
Old Apr 19, 2012 | 09:10 AM
Thank you all for the replies. Some of the parts are still on order waiting for shipment,
I am still goggling a lot on how to do the swap, once Im confident enough i might go follow you guys to ditch the mechanic.
Old Apr 19, 2012 | 09:24 AM
yes all 4 injectors came complete on D16Y8 head with intake manifold, I bought the resistor because the guy who help me out at the auto parts said i need it.
This is my first project car and i have search and price match parts i need but i guess i am not searching harder. : (
Thank you
Old May 21, 2012 | 08:23 AM
bogger8809's Avatar
hey guys i just did a d16y8-d15b7 mini me swap runs fine but got a really fast low high idle fluxuation any ideas i pluged each hole in the tb seperatly didn make a difference
Old May 21, 2012 | 12:16 PM
civicfanboii27's Avatar
its either a vacuum leak or distributor timing so check those
Old May 21, 2012 | 03:44 PM
ochata's Avatar
iat sensor? i have the same problem only because i havent made a hole into my intake manifold or air intake...
Old May 22, 2012 | 12:12 PM
runnamukk's Avatar
It will for sure fit. Lots of us have done it already, I just finished mine. Did a straight MPFI conversion (PM6 ECU) for now using the late injectors, so no resistor box. Runs like a champ. Plans are to move to P28 and VTEC in the future. Been driving it OBD0 for six months, so nice to move out of that!
Old Sep 6, 2012 | 06:29 PM
crvtectim's Avatar
You probably spun a rod bearing or bent a rod. Water and compression don't get along. Did you pull all the plugs out and turn the motor over to get rid of the water?
Old Sep 6, 2012 | 10:57 PM
EF_9's Avatar
Old Sep 7, 2012 | 07:40 AM
4drEF's Avatar
Keyboard Humorist
Originally Posted by jphillips_civic
Quick question for yall, 97 civic ex d16y8 sucked water into air intake cause k&n filter was run in front of passenger tire. Engine choked down, now it has a knock like a lifter tapping or something. Did I blow my head ?
You probably should have started a new post since your question has absolutely nothing to do with the original post.
Old Sep 7, 2012 | 12:18 PM
j3wman's Avatar
What is the point of having a search bar if nobody is going to use it...
I remember when i was a kid and my cousin had to figure this **** out on his own before Honda-Tech
Old Sep 9, 2012 | 10:43 PM
katcarson207's Avatar
I want to do a head swap on my ef... I think my d15 has about 70hp left in her. This one seems pretty easy.. what are realistic gains from doing this?
Old Sep 9, 2012 | 11:22 PM
91turbosohc's Avatar
DADDYDAVE
Jun 4, 2018 07:59 AM
s2k3_oc08
Aug 14, 2006 09:01 AM
lmiguelvv
Apr 14, 2004 11:21 PM
