verification of EF highway RPMs
Old Apr 11, 2012 | 04:23 PM
crxguy406's Avatar
Default verification of EF highway RPMs
This is assuming stock motor/tranny.
Can anyone who drives their rex on the highway a lot verify these stats? I did a bunch of searching and found these... but it was just a post by some random guy on another forum.
with 185/60/14 - 5th gear (si)
70 mph = 3,390
75 mph = 3,632
80 mph = 3,874
with 185/60/14 - 5th gear (dx)
70 mph - 3,101
75 mph - 3,323
80 mph - 3,544
with 185/60/14 - 5th gear (hf)
70 mph - 2,121
75 mph - 2,272
80 mph - 2,424
Old Apr 11, 2012 | 04:39 PM
netfreak's Avatar
Default Re: verification of EF highway RPMs
The Si stats match pretty close to what I get. 80% of my miles are highway.
Old Apr 11, 2012 | 05:18 PM
Thorshammer's Avatar
The HF stats are close to what mine were before the swap.
Old Apr 11, 2012 | 08:13 PM
TeamRedline89Hatch's Avatar
Sounds about right. I've had all those set ups lol hf trans was ridiculous long gearing.
Old Apr 12, 2012 | 08:41 AM
crxguy406's Avatar
Would an HF tranny bolt up to a D16a6? Or if not, could the gears be switched over? I'm looking for the best way to tame the highway RPMs on my SI build.
Old Apr 12, 2012 | 09:12 AM
24TEN's Avatar
PHANTOM MENACE
Yes and yes. I don't know off the top of my head but you may want to play with a gear speed calculator and see if it'd be worth it to run the HF 5th and final drive with Si/DX 1-4 gears (Si and DX gears are the same, only final drive makes the Si accelerate faster). I know from experience that running a tall gear set may actually hurt your performance. I converted my 94 CX (8valve essentially a newer HF) into a DX but didn't change the transmission. I could only take it for 4-5 days before I swapped transmissions. Every time I shifted it would drop it below the power band and I have to downshift one more gear than normal to make it up a hill even though I just added like 20hp with the DX conversion. The reason why it worked on the HF and later the CX models is because the 8 valve engine produce more torque down low in the rpm range.
Old Apr 12, 2012 | 09:40 AM
Yes it will bolt up just fine. I ran a sohc zc with the hf trans. Even with the zc (mpfi as well) doing 40 around town in 5th would bog lol. I did get a good laugh though after I hit 90 mph in 2nd gear at around 7200 rpm.
Old Apr 12, 2012 | 11:11 AM
24TEN's Avatar
PHANTOM MENACE
I did the same the first time I hit the freeway. I remember thinking "Man it feels like 2nd gear is never ever going to end!"
Old Apr 12, 2012 | 12:26 PM
TearSDMF89dx's Avatar
thats the whole reason i loved my hf ....i swapped in a d16a6 and it was like driving inside a motorcycle 90 in second was awesome ....it is a very livable setup if youre hard on your car anyways.... if i remember correctly we swapped in a dx final drive when that trans went into my buddys car and that was pretty damn fast through the first 3 gears just got "hf'ish" mileage when you werent getting on it
biglake1
12
Jun 19, 2013 04:29 AM
SiRay13
14
May 18, 2006 01:36 PM
nobigtoe
10
Jan 20, 2006 06:43 AM
MOCrxHf
Jan 19, 2003 10:11 PM
1990hondaHF
14
Sep 25, 2002 11:08 AM
