how do i take the trim off my da?
its a 92 da and yes i mean side molding. i know there is a bolt on one side on the door and its looks like your supposed to slide it out the clips but i couldnt get it off.
you need to remove the inside panel. roll up the window and using a needle nose pliers or any pliers and squeeze the clips together so you can push them out. there's several for the molding so take your time and do it right. Same goes for the fender molding and rear quarter panel molding. the fender one is the easiest to do.
buymesomedunks
Jun 15, 2013 02:58 PM
94
