Transmission & Drivetrain Gearboxes, Differentials, Clutches
Itr case cracked, need donor case, what options do I have?
Old Apr 11, 2012 | 01:56 PM
Evos's Avatar
Default Itr case cracked, need donor case, what options do I have?
I purchased a itr swap from my buddy that doesn't know much about cars. He totaled his car but the motor wasent bad beside some hairline stress cracks in the block and the back of the tranny where the T mount bolts up was completely ruined. I got a new block and took that and the head to the machine shop to get fixed up but my tranny still sits as is. I was just wondering what transmissions I could simply take my itr gears and factory LSD out and put it into. The tranny was rebuilt literatelly 5k miles ago with carbon syncros and GSR 5th(so says the guy he got the car from). I have seen a 94 b16a transmission with itr gears in but would say a ls tranny work or no because of the gear differences. I really appreciate any info to help me get my build on the road!
Old Apr 11, 2012 | 02:17 PM
94EG8's Avatar
Seagull Management
Default Re: Itr case cracked, need donor case, what options do I have?
Any B-series Hydro case will work, remember to shim the countershaft and diff when you put it together.
Old Apr 11, 2012 | 02:33 PM
boosted91crx's Avatar
i just recently got some hydro trannys in and im sure i can hook you up with a mint case. im in pa so you could also pick it up. pm me if interested.
Old Apr 11, 2012 | 10:27 PM
Mista Bone's Avatar
D Tranny Guru
I also have a clutch side case I don't need....
EK 2 9K
Jul 5, 2006 08:09 AM
NickQ
Mar 1, 2006 07:01 AM
the_23rd_letter
Aug 15, 2005 09:33 PM
92civicman
Jul 18, 2005 12:38 PM
B00ST2nR
Feb 14, 2004 10:05 PM
