How reliable is K20/K24?
Old Apr 11, 2012 | 11:24 AM
PARADOX_sf's Avatar
Default How reliable is K20/K24?
Hello.
How reliable is K20/K24 setup? It has oil pump cavitation problems, very narrow rod bearing (only 15mm), pistons speed at high rpm is extremely high and this leads to detonation problems. What do you think about this combo for a turbo setup? Is it reliable?
Thank you in advance.
Old Apr 15, 2012 | 03:27 PM
eg6ajk's Avatar
Default Re: How reliable is K20/K24?
Motor won't have too many issues when you start boosting but gears will need to be looked into.
Old Apr 15, 2012 | 03:59 PM
Deetz's Avatar
Crazy Honda Guy
If built properly, the combo should be very reliable. Of coarse, the best option would be to just go with a tsx K24a2, right from factory if you are worried about it.
Boosting a Honda engine will affect the life span of the engine, but many variables are involved
Old Apr 17, 2012 | 06:29 PM
tekoson's Avatar
Is it better to get a K24a2 into a stock rsx then eventually get a k20 head. Or is a k20A better to start off with. Is the K24 significantly heavier and would it do anything to the handling of the and rsx?
Old Apr 17, 2012 | 07:51 PM
Deetz's Avatar
Crazy Honda Guy
I think it's time you start reading up on the many threads about K series.
The K24A2 has basically the "same" head as the K20A2 head, pointless to change, of coarse if you read up on the engines, you'd know this.
Weight difference between the 2 and 2.4L, next to nothing, 20-30 lbs maybe......trust me, that is NOT an issue
Old Apr 19, 2012 | 08:35 AM
osc007's Avatar
Old Apr 19, 2012 | 08:47 AM
cetcivic's Avatar
no one wants to hear the truth
If I'm not mistaken,the k20a2 head has bigger ports than the k24a2 head..but,overall the k24a2 longblock is a great starting point..
-has real i-vtec
-higher compression pistons
-better cams
Than other k24 blocks
Old Apr 19, 2012 | 09:04 AM
osc007's Avatar
http://www.k20a.org/forum/showthread.php?t=2566
Old Apr 19, 2012 | 10:01 PM
Twenty47's Avatar
if you are gonna build the bottom end it doesnt matter what one and the k20 head flows a little better than a tsx.
Old Apr 22, 2012 | 05:24 AM
reignfterror's Avatar
transmission worries me the most.
Old May 4, 2012 | 05:24 AM
Deetz's Avatar
Crazy Honda Guy
if it bothers you so much, buy a 5 speed, they have zero issues
Old May 4, 2012 | 05:37 AM
Twenty47's Avatar
I've always heard they are the weakest one..
Old May 19, 2012 | 01:45 AM
Deetz's Avatar
Crazy Honda Guy
You are greatly mistakin. I have worked for Acura for years, and been around hundreds of rsx models, this is simply NOT true.....don't give in to hearsay bro
Old May 19, 2012 | 05:26 AM
Twenty47's Avatar
Idk what working for Acura would tell you. You can't compare cars when one has 130whp and a 6800rpm rev limit to a type s that is driven by lots Ricers. I've been around k series for a while and always thought the 2nd-3rd gear was notoriously weak. I had an ep3 and tons of people on the forums were always battling dealerships bc their trannies would grind. And that's with weak *** motors and no revs not like all motor k24 with 230-250whp.
And not to mention the ratios in the base Rsx are garbage.
Old May 19, 2012 | 08:43 AM
Deetz's Avatar
Crazy Honda Guy
LOL, 1st off, there is no such thing as a 130hp rsx!!
What does Acura have to do with anything? Well, lets see, i would be the one ordering parts for both cars that were and were not on warranty, including transmission parts. We did replace parts to fix 2nd and 3rd gear grind issues on some type S models. We never had and issues with base transmissions.
We also had an rsx club with 140 members, funny, not a single not of the base owners had any issues with theirs either, even over the eight years the club existed. If you had issues with his EP3, you probably have poor driving skills and wrecked the gears yourself
As far as having 200+ hp, one gear in a type S tranny, is no stronger that that of the base
Old May 19, 2012 | 09:04 AM
Twenty47's Avatar
where does it say my gears grinded? your post is hilarious and just proves you dont know what you are talking about..
a base rsx makes ~130whp.. do you know what whp stands for?
how do you not understand what i said when i explained why it isnt fair to compare a 130whp cars transmission failures when talking about the integrity of the tranny? people who buy the type s are going to drive it harder or they wouldnt have spent the cash. like i said the 6800 rev limit compared to 8000 will also protect the tranny. do you know how rpm's effect a trannies life and integrity? probably not but humor me. and then there is the more hp thing the type s has.
what im saying is from people with built engines, NA or turbo ive been told the 5 speeds arent all that. and like i said even if they were the ratios are dog ****. especially the base rsx. the ep3 has better ratios and final drive so its not as terrible but still crazy.
but tell me again why being a parts guy at an acura dealership makes you qualified to talk about boosted "race cars"? last time i was at the dealership getting a few things the guy was trying to tell me how k series was junk and b series was still the best. after i told him i was all motor especially lol.
and the 2nd gear grind was a known problem at the dealers with the ep3 tranny just like it was with the 3rd gear in the 06 si's. not from a few bone heads that couldnt drive. if you want to see my driving skills ill gladly let you put your foot in your mouth.
Old May 19, 2012 | 09:30 AM
Deetz's Avatar
Crazy Honda Guy
what ever dood, i could argue half of what you just said, not worth my time....and i never once talked about gear ratio's or eps tranny's prolems....do/say what ever the hell floats your boat. btw, the last stock base rsx i dyno'd made 142whp, not 130
Old May 19, 2012 | 02:19 PM
Twenty47's Avatar
you must be trolling
Old May 19, 2012 | 06:56 PM
turbociviccoupe's Avatar
k transmissions are crap. you are both arguing about the same point. no matter 5 or 6 speed they both suck.
Old May 19, 2012 | 06:58 PM
Twenty47's Avatar
but but but he said the 5's have zero issues brah
Old May 22, 2012 | 08:05 AM
zookiezook's Avatar
From: b-lo 2 the roc NY, south BX to the heights NYC, central 2 south FL
always thought the 2nd-3rd gear was notoriously weak. I had an ep3 and tons of people on the forums were always battling dealerships bc their trannies would grind. .
ill agree to an extent
2nd or 3rd gear will pretty much always be the first gears to mess up on any tranny
2nd gear went bad on my boys 06 si but he drives the **** out of hit
but the 06 si is better overall that the rsx or rsx type-s or the ep3 si
the ep3, and rsx's clearly fall behind in overall performance to the 06
so why more people run rsx k20's confuses me , maybe cause they think there good and have the letter K in it and they cost less
but like deetz said people can argue all day ups and downs and all that and we dont want to do all that, just stating some stuff is all
Old May 22, 2012 | 08:13 AM
zookiezook's Avatar
but to answer the original question
its all about what u want to do
if you want to keep it all motor and rev to red line youll b fine
if u want to run a turbo on stock internals and run 35lbs you probably wont be fine lol
Old May 22, 2012 | 08:23 AM
kyden's Avatar
none of that makes ANY sense.
Old May 22, 2012 | 08:29 AM
Twenty47's Avatar
Lol this. People are clueless.
Old May 22, 2012 | 08:47 AM
Twenty47's Avatar
Let me dumb this down. Saying a type s trans is weaker bc they break more is like Ferrari saying their cars are more reliable because they serviced fewer cars last year than honda. Not taking into the fact they Honda sells more cars in a few hours nation wide than they do in a whole year.
Everyone has type s trannies in their built cars. Very very few peoe have 5 speeds. Same with z3 trannies they aren't as easy to swap. Just because base Rsx trannies dont break at 130whp with old people driving them doesn't mean they are stronger. There's Probably more type s tranny kswapped hatches in 1 major city than there is swapped cars using a 5 speed in the nation. So of course they break more.
If I owned a fast food restaurant this would be my claim. "my place is cleaner than McDonald's bc we had less cases of food poisoning last year". When I'm 1 place and there are how many McDonald's.
Btw I made 30+ passes last year with 02-04 type s gears, 300+ whp and full throttle shifts every time. In a heavy car at that. Never a lockout or grind. doing a stroker now so I'm sure it's gonna break but any k tranny would. Except an Rsx 5 speed would probably make my car a second slower lol.
