Integra cluster swap help
Ok do the shell I had the guy before me started the integra cluster swap. I finished it all the gauges and everything works I am having trouble with the Vss. Before I wired the Vss as soon as I turn to key to on position my speed goes up to 40 mph. Then I thought I hooked the Vss up right and the same thing. I have a b16 obd1 ef. Any help would be great. I know the signal wire should go to the orange wire and the power said any black and yellow wire. But I also har to run one to the ecu? I'm assuming Is b10 a yellow blue wire at the ecu? Not sure
