removing GSR spoiler for TYPE-R [hole plug] question
just wondering, all my integras always came with type R wings or none so making the holes to mount it was easy, now this integra has the GSR spoiler..
the type r wings bolt up to those holes NP but, there is third holes on each side, 1 for a wire harness to power the brake light and one on the opposite side for a white plug.
the two holes are the same size i was wondering if anybody knew of a part number or size for a grommet i can put in them or a way to close them up so they don't leak?
i think the antenna delete grommet will be to obig
PART NUMBER [82871-671-000 GROMMET (25MM)]
anybody know of a grommet that will fit there or a better way to plug them ?
just wondering, all my integras always came with type R wings or none so making theh oles to mount it was easy, now this integra has the GSR spoiler..
the type r bolts up to those holes NP but. theres third holes on each side, 1 for a wire harness to power the brake light and one on the opposite side for a white plug.
the two holes are the same size i was wondering if anybody knew of a part number for a grommet i can put in them or a way to close them up so they don't leak?
i know when i took out my antenna i used a grommet to plug the hole and it worked perfectly fine and never leaked, it looks to be the same size hole but i forgot the part number for that as well heh, i even had a spare one here but i can't find it ;(.
i will try them i have them in my tower, that's a good idea actually, never thought of that.
I got a hunch though that the holes i need to plug might be just a tad bigger.
i'm assuming the antenna delete plug will be too big the part number for that one is 82871-671-000 GROMMET (25MM)
i wonder if anybody actually knows the correct size of that hole so i could order proper ones hehe.
chatman_55
Feb 7, 2008 06:13 PM
