91 hatch 'modest' build
i picked a pretty clean white shell up (11/11). iv done a couple things since. started my engine harness, tucked some stuff, did most of the body work, stripped the rest of the interior, and started on the suspension.
i got a pretty sick deal on a complete b18 long block that had a 'broke timing belt'. i broke it apart to find two burn exhaust valves on cylinder 2. no other damage. i sent both the head and block to a local machine shop to be freshened up a bit.
full set of seats from a 99 hatch
dry iced
this is about where my brake prop vlave will be mounted
start of my wiring harness. i harvested the entire section of whatever i needed from the b18 harness.
ill take some more pics of the wiring soon. im a bit further than these pictures.
center console from a 98 integra. freshened it up a little.
pressed some new bushings
sway bar for a 92+ civic adapted.
1/4'' plate
welded for a little reinforcement
dry iced
1/4'' plate
ridin98civic
Jul 30, 2008 11:22 AM
