91 CRX B16 /Clean SC/NC boarder 2nd Owner 4k obo
Old Apr 10, 2012 | 01:25 PM
sp00nek9's Avatar
Default 91 CRX B16 /Clean SC/NC boarder 2nd Owner 4k obo
for sale, may consider trades. is a 1991 honda crx dx. i purchased it from the original owner in 2001. second owner car. the mileage is 141,xxx the engine was swapped in 2005. it has NEVER been to the track or the road course. the car hasnt been driven that much over the years as I have several other project cars and a daily driver. $4k OBO contact me at h3rodesigns@gmail.com
mods/about
clear title
jdm b16a complete engine and trans swap (purchased from larry at import auto salvage) 30k on engine runs very strong
(car was checked over by jack at p1 auto after the swap)
stock jdm harness was sent to hasport for wiring conversion (the car is still obd0) for the factory look (no cut connectors etc) everything looks factory
exedy clutch and pressure plate
fidanzia lightned flywheel
aem cam gears
aem fuel rail
aem fuel pressure regulator
ctr pulley
edelbrock header
2 1/4 exhaust
avid motor mounts
new timing belt
new water pump
new oil pump
new valve cover gasket
msd spark plug wires
new rotor button
iridium spark plugs
walboro 255 fuel pump
ek dual core radiator (custom welded tabs on sub frame) looks stock
factory honda trans M/T trans fluid
always ran full synthetic oil
vis carbon fiber hood (needs to be re cleared)
original real deal wings west wing (no longer in production)
99-00 civic si wheels with good kumho tires
authentic jdm cr-x vtec center taillight insert
stock front brakes
90-93 integra gs-r rear disc conversion (these are hard to find)
energy suspension rear trailing arm bushings
sprint lowering springs
tokico blue shocks
all interior is there even the back pieces
custom cluster white face gauges (dont light up) back light still functional with orange painted needles (i like the look of the ep3 cluster at the time)
drivers seat has small tear (which can be easily fixed) in really good shape considering most seats in these ef's are usually trashed
the car will need a wheel bearing soon as it makes a little noise, the glove box tabs on the bottom are broken but it stays in place (just needs new box), windshield is cracked other than that it is in great shape let me know if you have any more questons
*pics* (the hood is popped in the pics)
90jdmcrxdude
Jan 5, 2012 05:07 PM
stellhornata
Jan 4, 2009 05:14 PM
tomek5x
Jan 14, 2008 05:08 PM
user 25438239
Feb 23, 2007 01:02 PM
crx2nr822
Nov 6, 2005 06:48 PM
