***High Compression H2b eg hatch part out****
aem cam gears...80
port/polish h22 Head fresh out the machine shop... 1300
3 angle valve job
DH racing valve springs retainer
stock valves
new oem valve seals
powder coated gunmetal valve cover
New RMF replica Headers(modified for h2b)...400
h22 block/h23 crank.... 2200
sleeved,88mm wiesco 13:1 pistons with new rings h23 95mm std crank micropolish and balance crank acl rod bearings clevite mains SGI h-beam rods
h23 single crank pulley
new oem oil pump/rear main seal
balancer shaft deleted
u can contact me at 305 281 6495 ryan
3 angle valve job
stock valves
new oem valve seals
2012, cams, comp, compression, h22, h23crank, h2b, hatch, high, micropolish, part, site98158194248, skunk2, tracked
