... diy wideband power and ground wiring
Old Oct 11, 2002 | 03:22 PM
1.8T_EG's Avatar
Default ... diy wideband power and ground wiring
... gettin ready to install the wideband this weekend... anyone got any suggestions for what wires to tap for power and ground?... dash?... ecu?... also, if you can gimme specific wires... like ecu pins or wire colors at the dash... thanks in advance...
Old Oct 11, 2002 | 03:24 PM
rjardy's Avatar
Default Re: ... diy wideband power and ground wiring (1.8T_EG)
Use a good ground from underneath the dash, or if you really want to be sure run it to the block or the battery.
Rob
Old Oct 11, 2002 | 03:35 PM
blufke's Avatar
Default Re: ... diy wideband power and ground wiring (rjardy)
im interested to know too. my techedge should be here soon.
Old Oct 11, 2002 | 10:59 PM
1.8T_EG's Avatar
Old Oct 11, 2002 | 11:15 PM
rjardy's Avatar
Guess it wasnt clear. You can use any good ground, **** you can use the same thing that you grounded your stereo to, or tap into the ecu harness.
Rob
Old Oct 13, 2002 | 12:48 AM
1.8T_EG's Avatar
what about power???
Old Oct 13, 2002 | 01:05 AM
rjardy's Avatar
I would tap power from the ACC of your ignition switch.
Rob
Old Oct 13, 2002 | 01:09 AM
blufke's Avatar
Rob
is the accesory wire the one you wire your amp to so it only comes on when the car is turned on?
Old Oct 13, 2002 | 02:21 AM
rjardy's Avatar
Default Re: ... diy wideband power and ground wiring (blufke)
Yeah thats the one, no need for the wideband system to get power all the time.
Rob
Old Mar 15, 2003 | 07:51 PM
mskibbz-T's Avatar
correct, but you should have the accessory wire go to a relay to switch on power directly from the battery for your controller... I wouldn't run it directly off the accessory wire.
run a fuse inline on the battery(+) ---> relay(12V in) wire for safety.
Old Mar 16, 2003 | 12:15 AM
sparkz's Avatar
Default Re: ... diy wideband power and ground wiring (mskibbz-T)
if you have the older techedge wideband 1.0, then you should connect directly to the battery. it needs at least 13.xxvolts to work
Old Mar 17, 2003 | 05:04 PM
mskibbz-T's Avatar
Default Re: ... diy wideband power and ground wiring (sparkz)
my bad, didn't mean to spread misinformation
GagnarTheUnruly
Engine Management and Tuning
Sep 1, 2011 11:34 AM
footstinker
Jul 7, 2010 10:58 AM
tommymoose
Audio / Security / Video
May 1, 2006 06:40 PM
RTW DC2R
Apr 24, 2006 06:08 PM
flip1199
Mar 13, 2005 08:45 PM
