Will 17x9 rota grids fit my em2
Old Apr 9, 2012 | 04:29 PM
em2crusin's Avatar
Icon2 Will 17x9 rota grids fit my em2
im looking to get grids for my em2 but im unsure if it will fit with its 9" width ive seen them on other em2s before but didnt know if anything extra was required to fit them. i will be lacing them with 215/40/r17 also.
Old Apr 9, 2012 | 04:53 PM
m_shake's Avatar
Default Re: Will 17x9 rota grids fit my em2
Ahh what offset home boi? Kinda makes a big difference...but plan on rolling the fenders. Lacing them...wtf lol
Old Apr 9, 2012 | 04:55 PM
Dc4LsTeG's Avatar
EK9
X2 on offset.. also how low is your car?
Old Apr 9, 2012 | 06:05 PM
toyomatt84's Avatar
Sanji
215/40/17's are rated for up to 8.5" wide wheels, so the tires are undersized for the wheels. Also, depending on what offset you go with, you're going to have quite a lot of work to do to both the sheet metal and run quite a lot of negative camber to fit them. Fitting 16x8 +35's with 225/50/16's required almost 2 degrees of negative camber and rolled/cut rear quarter panels. Then, in the front, it required almost 3 degrees of negative camber, removed fender liners, and rolled/slightly pulled fenders.
Old Apr 10, 2012 | 07:48 AM
em2crusin's Avatar
its a 42mm offset and the tires would be stretched and my cars only on springs right now with a 1.5 drop so i have a bit of room
Old Apr 10, 2012 | 03:24 PM
toyomatt84's Avatar
Sanji
I hate to say it bud... but...
From the Forum Rules and FAQ:
10. Do not ask about "stretching" tires onto wheels that are too wide.
All such topics will be locked. Tire manufacturers determine the wheel widths onto which each model and size tire can be mounted safely, and you can find the range of these wheel widths in the specs on their websites as well as those of retailers like the Tire Rack. Mounting tires onto wheels outside this range of approved wheel widths is unsafe because it can, and often does, result in the buildup of excessive stress and heat in the tire sidewalls, which can lead to the tire "popping the bead" and/or tire failure. Make sure your tires are mounted on wheels whose widths are within the approved range.
This type of question is better suited for the Appearance forums, if anywhere.
PS. You may get some clearance issues to the rear trailing arm, depending on how much camber you have.
hondahoward
21
Dec 3, 2013 10:38 AM
jdmlude87
May 15, 2009 07:50 PM
tsgeekz
May 11, 2009 01:55 PM
the all out kid
Suspension & Brakes
Jan 31, 2009 10:07 AM
ef9robert
May 7, 2008 09:38 PM
