Coolant temp gauge not working
Old Apr 9, 2012 | 03:36 PM
jdmef69's Avatar
Default Coolant temp gauge not working
Ok here's the deal the guy who owned the car before instead of using the obd1 conversion harness he basically made it obs1. Well when I got the car it would start wires were messed up. Well I got it to start. I got all the gauges to work except the temp. It has no power at the cluster. No power at the sensor on the thermostat housing. I don't know where else to check. Any help?
Old Apr 9, 2012 | 03:37 PM
jdmef69's Avatar
Default Re: Coolant temp gauge not working
It's a 91 ef si hatch with b16 swap.
Old Apr 10, 2012 | 04:23 AM
el crapitan's Avatar
the sender should be a single pin. passenger side of head, below distributor. use a multimeter to test it's resistance. cold, then hot. see if it falls within spec
Old Apr 10, 2012 | 07:15 AM
jdmef69's Avatar
I actually figured it out. I started tracing the wire from the teremo stat housing and found it was cut. Re soddered it and everything works. Thanks for the response tho.
dom_ef1992
May 4, 2014 08:07 PM
ZCHondaCRX91
May 15, 2012 06:33 AM
SeraphimKidd
11
Aug 26, 2009 08:55 PM
zippakilla
Feb 21, 2009 11:02 AM
cubanbear16
May 30, 2006 03:45 AM
