Half shaft issues
Old Apr 9, 2012 | 02:08 PM
jphil101's Avatar
Default Half shaft issues
I recently bought new axles for my car, b16 cable s1 tranny, and had to buy new half shaft bc other was female and hasports is female. So I bought half shaft that was male and the journal right b4 splines is bout 8th of inch too small in diameter compared to other half shaft so my tranny is leaking. Need help to see what options I have at this juncture
Old Apr 10, 2012 | 06:21 AM
jlicrx's Avatar
Default Re: Half shaft issues
just swap the driver's side axle seal in the transmission for one from 94-00 Integra
Old Apr 12, 2012 | 04:29 PM
jphil101's Avatar
I went to O'reily auto parts and ordered axle seal for driver side and didnt work
Old Apr 12, 2012 | 05:06 PM
beansandrice's Avatar
Get a dial gauge and check the I.d. Of the axle hole on the trans without the seal then take a measurement of the axle plug (end that goes into tranny) take both measurements to Napa and they can find one that will fit.
Old Apr 12, 2012 | 06:07 PM
jdmef69's Avatar
Are you using a automatic half shaft?
Old Apr 12, 2012 | 10:48 PM
jphil101's Avatar
No. It's manual. Got it from streetimports.com
Old Apr 13, 2012 | 09:31 AM
carlos1890's Avatar
Double check if its off of a manual. I had the same issue on my swap, it took me for ever to figure that out. Turned out that was my problem, i had a half shaft off of an auto. I used 90-93 teg manual axles and i shaft. I also had the seal problem, try to get a hold of a 90-93 teg seal, worked fine for me. Good Luck...
Old Apr 13, 2012 | 11:33 AM
jlicrx's Avatar
90-93 seal is what is needed with 90-93 intermediate shaft with female outer end
94-2000 seal is what is needed with 94-2000 intermediate shaft with male outer end
Old Apr 13, 2012 | 07:55 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
This is correct... You are doing something wrong/don't know what you are doing or looked up the parts wrong. Also, you can't swap seals side to side as the OD is different from passenger to driver.
Old Apr 15, 2012 | 01:35 PM
carlos1890's Avatar
Check the I Shaft again, if it says sk7-N it's from an auto. A manual I Shaft will say sk7-J,witch is what you need
rotaryjunky
May 20, 2015 10:47 PM
LuckyJDM
10
Feb 2, 2014 08:01 AM
jphil101
Transmission & Drivetrain
Apr 13, 2012 05:45 PM
13g-crx
Feb 16, 2007 11:32 PM
Desperado
Apr 10, 2003 12:51 PM
