teins or jic
Old Oct 11, 2002 | 02:41 PM
HP-MuGEn DC5's Avatar
Default teins or jic
okay peeps im debating on what coilovers i should get. Need help i have an eibach prokit and m not sure if i should return it. So need your help people! which one! thanks!
Old Oct 13, 2002 | 08:23 AM
baonest1's Avatar
Default Re: teins or jic (HP-MuGEn DC5)
id say teins cuz they cost about a grand and made in japan.. dont know much about the JIC tho, maybe the same.
Old Oct 13, 2002 | 11:17 AM
mooboygsr's Avatar
Default Re: teins or jic (baonest)
JIC are better then teins... and more expensive... in the 1600-2000 range... plus i don't know if they'd be to good for street use...
[Modified by mooboygsr, 8:17 PM 10/13/2002]
Old Oct 13, 2002 | 03:28 PM
baonest1's Avatar
Default Re: teins or jic (mooboygsr)
damn, i didnt even know that. go with the JIC
Old Oct 13, 2002 | 06:58 PM
zeroryde's Avatar
the JIC's are so much better than the Tein SS or HA's. First of all its somewhat made of aluminum, no rust like the SS or HA, same spring rates of the SS, but more aggressive valving than either. 15 way adjustable dampening on rebound, but most important (besides camber plates and pillowball mounts) is adjustable damper length, aka... there's a perch for the lower control arm attachment of the damper which means you don't have to mess around with your preload spring rate in order to lower your car. Therefore you can make use of having a good amount of suspension travel without worrying about ur strut bottoming out (hitting the top of the strut). Or if you want it in simplier terms, there's a perch for the spring level and another perch for the damper (beneath the spring perch)... you can lower the car without moving the spring up and down..therefore leaving the spring rates at ur desired preload rate (unsprung)... sorry I probably confused a lot of people...but if you read it a bunch of times, u'll get it...
...JIC's are more "harsh" than the teins as they're more aggressive, but if you plan on autocrossing or doing track events, they're worth every penny... I just wish I had money for them..
Old Oct 13, 2002 | 07:30 PM
jdmjunky's Avatar
Default Re: teins or jic (zeroryde)
teins, teins, teins!!! granted that the jic are great but teins have sooo many more variety in setup - from comfort, flex, to sport, ha, to race, ra, re and full race, n1's...just my two cents...i have ha and i think it's perfect for street...
Old Oct 13, 2002 | 09:06 PM
Mario's Avatar
You're comparing apples to oranges. A JIC coilover within the same price range as the Tein SS or HA is the JIC SF1, it is neither aluminum, or 15 way damping adjustable. With that in mind, the HA or even the SS are still better choices.
In order for one to take advantage of the 15way adjustable damping, aluminum body, and adjustable shock body with a JIC suspension, you'll need to spend ~$1800 on the FLT-A2 model.
For the same price, the TEIN RE can be had. Which boasts the same features as the JIC.
Hah, you don't even own one?
Consider this, who would you trust for your suspension needs?
JIC, who makes exhausts, seats, strut bars, etc.
or
TEIN, who makes springs, shocks, and coilovers exclusively and nothing else.
Old Oct 13, 2002 | 10:39 PM
jdmjunky's Avatar
Default Re: teins or jic (Mario)
dudes, i second that! tein has nothing else in mind except suspension...can't say that about jic - not to flame but just the facts.
Old Oct 14, 2002 | 11:19 AM
acura_typer's Avatar
Banned
or
So, Spoon, Mugen and a handful of other JDM companies make that other stuff than shocks/springs, do you think that really matters?
JIC > Tein - plus you can get them serviced here in the US too. Get them custom valved or special spring rates too.
Old Oct 14, 2002 | 11:41 AM
Mario's Avatar
Default Re: teins or jic (acura_typer)
Spoon & Mugen do not make their own coilovers/shocks. Who do they contract? Suprise...SHOWA. Who/what is SHOWA? Suprise...they are a shock/strut/damper manufacturer (along with other suspension related components), in addition to being an OEM manufacturer to Honda, Suzuki, Mitsubishi, Ducati, etc.
If these two highly esteemed "JDM companies" rely on a corporation that specializes on shock absorbers to develop their aftermarket line of Coilovers; Spoon, Mugen N-1, N-Zero, Lowdown, etc. Why not think along the same lines and trust TEIN more so than JIC? If for no other reason than simply because they can (at the very least) devote more research and development towards ONE single line of product.
TEIN USA is available for those services as well.
Besides, how long have JIC been around? Not as long as TEIN I can tell you that much.
jdmjunky's Avatar
or
i don't think his intentions are as severe as the analogy i am about to give...but if you were in need of a heart transplant. would you opt for a heart surgeon or just a general surgeon, or perhaps a neuro surgeon?
inj3ntek
Dec 7, 2007 09:03 AM
stock ek
Suspension & Brakes
Jan 8, 2007 02:26 PM
numbnuts22715
Suspension & Brakes
Dec 28, 2005 12:52 PM
GumballNA
Dec 27, 2004 08:10 PM
JunIntegra
Jan 15, 2004 10:22 AM
