GSR Swap Major Oil Leak Around Head. Help!
picked up a complete gsr swap. wento to go startup the car and oil squirted all around the transmission side and backside of the motor. its not the distributor seal or vtec solenoid gasket for sure. its not a slow leak its spitting oil out. i'd say just about a quart of oil came out within 10-15 seconds after startup. had to shut it off. what the F could be wrong with it?
You could not see where the oil was coming from, maybe have someone crank it while you look or do a bypass jump so you can crank and look at the same time. 94
its leaking between the head and block but its coming out from all around the tranny side and back of the motor. could it have a wrong headgasket installed or even installed on backwards? incorrectly torqued head bolts? i mean this biatch is gushing out oil.
Ditto the above^^^
If it is comming from between the block and head, it may be the HG, [wrong one, not installed properly, but my guess would be, [if it's pumping out as fast as you say] it is a bigger problem then just a HG or how you cranked the head down, [although still possible] a warped head, deck or both.
Clean it and see exactly where it is coming from, if your sure it is from between the block and head, pull the head.94
yeah i'm gona have the the shops mechanic re-do the headgasket tomorrow since the motor is still under warranty. the engine started up but it oil was coming out like no tomorrow.
got an oil leak and i cant post a thread cause i just signed up. the leak is right under the cam gears http://s11.postimage.org/urbsjxqwj/Untitled.png Please help asap
Was the head recently R&R'd? Could be a HG problem or the machine shop may have left a plug out on the head.
swizz977
49
Nov 20, 2011 03:09 PM
