jdm front end
Old Apr 8, 2012 | 04:55 PM
ryanmh22's Avatar
Default jdm front end
okay so i have an 88 crx si and i was wondering will an ef8 sir front bumper fit?
Old Apr 8, 2012 | 08:12 PM
stackedhouse's Avatar
Default Re: jdm front end
No
Old Apr 8, 2012 | 08:18 PM
Deetz's Avatar
Crazy Honda Guy
The bumper on the 90-91 style jdm front ends is in fact different. It is about 2" further out forwards, and the headlights are much different in size
Old Apr 8, 2012 | 11:16 PM
LudeEFv2.4's Avatar
My old title sucked.
It will fit... However you would need the rest of the EF8 front end, otherwise it will look tacky. And by tacky I mean terrible.
Old Apr 9, 2012 | 05:22 AM
Typhoon_EF9's Avatar
nice to know i was wondering the same thing
Old Apr 9, 2012 | 11:28 AM
gotkimchi's Avatar
You should be able to re-use the USDM fenders.
Old Apr 9, 2012 | 11:59 AM
KCHC's Avatar
what about bumper support?
Old Apr 9, 2012 | 01:11 PM
korax's Avatar
The bumper support is totally different on the japanese EF8. In reality the EF8 bumper support doesn't fit with out the support brackets either. They are two squares on each side that the four bolts on the support go into. You will have to modify the support so the bumper doesn't sag if using the ED brackets.
Old Apr 9, 2012 | 02:53 PM
Deetz's Avatar
Crazy Honda Guy
JDM bumpers don't use rebars. They are a thin metal bar that lines the iside of the bumper cover, thats it
Old Apr 9, 2012 | 08:03 PM
ryanmh22's Avatar
okay so i need front bumper, bumper bracket, bumper support, head lights, hood and?
Old Apr 9, 2012 | 08:28 PM
Deetz's Avatar
Crazy Honda Guy
The bumper should be still attached with the mounting brace. Yeah, you need headlights, hood and in my opinion, the proper T bar
Here is the front end i bought something like 5 years ago, everything i needed for the swap
front cut
and hood
and t bar, notice the spacing around the hood latch
Old Apr 9, 2012 | 11:24 PM
ryanmh22's Avatar
where might i get a hacked off front end like that?
Old Apr 10, 2012 | 04:15 AM
el crapitan's Avatar
the t bar's sweet too cuz it has a cut out for the ef8/9 air intake duct which pulls cooler air from in front of the rad instead of behind. kinda cool.
Old Apr 12, 2012 | 03:54 PM
ryanmh22's Avatar
so the lights will mount up in the usdm core support right?
Old Apr 12, 2012 | 04:48 PM
jdmboyef9's Avatar
yes the headlights will bolt up but the hood won't latch without the t-bar as said above
Old Apr 13, 2012 | 04:47 AM
ryanmh22's Avatar
okay thank you guy i was just making sure didnt want to order a mess of parts only to find out it wouldnt work
Old Apr 16, 2012 | 08:05 AM
KCHC's Avatar
are you in joplin, MO? you can get a front clip from hmotors i believe.
Old Apr 24, 2012 | 03:51 PM
ryanmh22's Avatar
ya im in joplin mo and ill have to look into it
Old Apr 24, 2012 | 04:01 PM
M-benz's Avatar
Originally Posted by Deetz
front cut
Does this front lip came with the bumper ? Where I can find one like that to attach to mine 89 si hatch ?
Old Apr 24, 2012 | 04:47 PM
jdmboyef9's Avatar
First that's a jdm crx lip, second even a usdm crx lip will not even come close to fitting an 88-89 civic front bumper. It is a lot more rounded and won't come close to fitting. I have both the 89' civic si lip and 90-91 crx lip new and they are night and day different
Awsom-o 4000
11
Oct 24, 2010 02:11 PM
thanh4o8
May 27, 2008 11:22 AM
CrX-WoRlD
Dec 30, 2007 06:38 AM
synner
22
Jul 15, 2007 04:44 AM
jadugartir
Jan 18, 2005 07:04 AM
