tire ?
Old Apr 7, 2012 | 03:42 PM
jdmsir4dr's Avatar
Default tire ?
i have some 16inch rims with a 38 offset ... what tire size do you guys reccomment i dont kno much about tires so i need help
Old Apr 7, 2012 | 03:57 PM
DELshaneSOL's Avatar
Default Re: tire ?
205 55
Old Apr 7, 2012 | 04:07 PM
grumblemarc's Avatar
The Grumpiest
Default Re: tire ?
I run a 205-45
Old Apr 7, 2012 | 04:22 PM
ej1ryder's Avatar
Default Re: tire ?
Dont run anything wider than 205 without "modded" or "rolled" fenders, unless ur at stock ride height. Lol a 55 series sidewall on a 16" tire would look HUGE and give you clearance issues if lowered. As a general guideline, the larger u go from stock wheel size: the smaller u go on sidewall hight, for example: my ej1 stock is supposed to run 175/65 14, (175 would be the width, 65 is the sidewall height, and 14 is the wheel size) so if u go 15 u would want to drop that sidewall # to either 55 or 50 depending on tire width, anything 195 width and up id drop it to a 50 sidewall, and if u ran 16's u would want to drop sidewall height to 45 to compensate for increase in wheel size. U followin me? Hope this all helps and good luck and be PICKY at ur tire shop, alot of times they take the easy way out.
Old Apr 7, 2012 | 04:29 PM
Default Re: tire ?
I run 205 55 no problem Also depends what car
Old Apr 7, 2012 | 04:41 PM
ej1ryder's Avatar
Default Re: tire ?
Well since this was posted in the 92-00 forum i assumed some variation of eh/ej. Wich makes this a ride height sensitive issue, and also a driving style issue. Ive worked at 3 tire shops out here in the bay and i am a fully certified tire tech thru americas tire (sounds cheezy i know) but if ur lowered substantially i dont recommend a 55 sidewall on any 16" wheel, and that goes for any ej/eg/eh/ek or even dc/db tegs. It looks ugly and is unecessary on our small cars. Although if ur at stock height u should have no issues, u will just look rediculous.
Old Apr 8, 2012 | 06:26 AM
jdmsir4dr's Avatar
Default Re: tire ?
205/45/16 front and 205/50/16 rear ..would that set up be fine
Old Apr 8, 2012 | 06:40 AM
The Grumpiest
Default Re: tire ?
Why does it need to be taller in the rear? What do you plan on doing when it comes time to rotate the tires?
Old Apr 8, 2012 | 06:47 AM
jdmsir4dr's Avatar
Default Re: tire ?
i was jw since my friend was giving me some spare 205/50/16 free that are fresh ...my car is more lower in the front than in the rear its a ek 4dr...so u recommend just getting 205-45-16 all around
Old Apr 8, 2012 | 07:12 AM
toyomatt84's Avatar
Sanji
Default Re: tire ?
The car dictates tire size more so then the wheels you have for it. Since you have an EJ6/8 sedan, both 205/45/16's and 205/50/16's would work. But, the 205/45/16's would be the better choice for your chassis.
Old Apr 11, 2012 | 12:40 AM
ggavgg's Avatar
Default Re: tire ?
is your car lowered ?
Old Apr 11, 2012 | 05:21 AM
ChristianL's Avatar
Default Re: tire ?
What's your wheel width? That'll make a difference in tires, too. Gotta find out what that is before you can start determining tire size.
FWIW, my EK sedan is on 205/45-16 tires with 16x7 Enkei RPF1s with a 42 offset. I'm on a stock height suspension, haven't had any rubbing issues, and they're flush with the fenders.
grnaccord
Jan 4, 2019 08:17 AM
Moody Inc.
Jun 22, 2018 11:12 AM
tonee_
Mar 11, 2011 12:23 PM
accordinglyevil
Nov 19, 2007 06:34 PM
hondaracin24
Jun 22, 2005 05:05 PM
