Broken bolt on rear upper control arm
Old Apr 7, 2012 | 12:31 PM
Dancing is Forbidden's Avatar
Default Broken bolt on rear upper control arm
I was going to install a camber kit on my buddies 89 CRX today and when I got the wheel off I noticed that one of the bolts was loose. Aw hell. Well then I noticed that it was that the nut inside the chassis had sheered off and was just free spinning in there. What do I do? And then how do I put a new bolt in?
Old Apr 7, 2012 | 01:44 PM
whited's Avatar
CRX God
Default Re: Broken bolt on rear upper control arm
If you take of the rear interior panel you maybe able to get access to the nut. If you do, post pictures. From there you can either re-weld the nut back in place, or just use vise grips or a wrench on it.
Old Mar 3, 2013 | 04:59 PM
sdaoteuang's Avatar
Did he fix? How did he get the screw out when it just spends freely?text me at 3375778842 and tell me I need to fix mines ASAP!
Old Mar 9, 2013 | 10:45 PM
Bense's Avatar
i'm gay
Bense's Avatar
reply.
180 no comply... and Elissa Steamer does them better than you... switch stance.... fgt
Old Mar 9, 2013 | 10:48 PM
lol! she does.
Old Mar 9, 2013 | 10:50 PM
I got fixed it! What I did was take an angle grinder and grind a hole out of the back in the wheel well and just used a wrench to hold the nut in place and then put on a new one I got from the store to fit the UCA bolt. Hope this helps. Ill text you tomorrow, creep.
Old Mar 9, 2013 | 10:51 PM
Bense's Avatar
but i'll bet your /steamer/ stinks worse than hers
Old Mar 9, 2013 | 11:02 PM
Bense's Avatar
In before some n00b tries to ramble on about how you have "tainted" the "structural integrity" by doing this.. lol
Old Mar 9, 2013 | 11:39 PM
Bense's Avatar
Jeff, are you a strainger to love?
Old May 26, 2013 | 10:42 AM
Jarrat's Avatar
HOLLY DOG POOP... why wouldn't you use a hole saw then find a gromet to fill the hole to make it look clean???? Thats crazy ugly!!!
Old May 27, 2013 | 03:39 PM
sstupid's Avatar
10 Year Member
You've ruined the structural-integrity of the car. You'll likely DIAF, now. Not because of the hole, but because your car is yellow.
Old May 27, 2013 | 09:14 PM
Bense's Avatar
Old May 28, 2013 | 07:13 PM
Function over form, bo.
Old May 28, 2013 | 07:27 PM
HongoRLS's Avatar
I had the same prob on ma hatch. Wat I did is I found a good welder n told him to cut ard the bolt as small as possible and then put a screw facing out this time that way If it happens to slip again I could vice grip it. Jus remember DO NOT BEND THE SPOT WHERE THAT SCREW GOES! It's for ur camber kit, your wheel will never line up and ull be able to tell if jus a lil is bent out of place. Hope this helps. Sorry no pics.
Hanmin
Oct 20, 2011 12:19 PM
irideslammed5021
12
Mar 28, 2007 04:02 PM
FuLlRaCe XLR8R
Suspension & Brakes
Feb 27, 2007 11:33 PM
gunnis
12
May 24, 2006 08:40 PM
thaimonkey
15
Jul 7, 2005 10:42 AM
