New valves for B16 what would you choice??
Old Oct 11, 2002 | 12:58 PM
evo's Avatar
evo
New User
Default New valves for B16 what would you choose??
I'm looking for new set of valves for my B16. The JUN'3, valve spring, ti-reatiners and CTR piston will install at the same time.
1. ferrea valves
2. ITR valves
3. Shunk 2 racing valves
Which would you choose??
thanks
[Modified by evo, 12:38 PM 10/12/2002]
Old Oct 12, 2002 | 03:39 AM
evo's Avatar
evo
New User
Default Re: New valves for B16 what would you choose?? (evo)
anyone?
Old Oct 12, 2002 | 07:13 AM
Tbone's Avatar
Joe Alaniz says that he can get better flow out of stock valves than any aftermarket ones. He also proved to me that oversize valves in NA applications are worse than stock size. He backed all of this up with flow charts.
Old Oct 12, 2002 | 08:21 AM
Sonic's Avatar
Default Re: New valves for B16 what would you choose?? (Tbone)
Go with ITR. They are much lighter than SS valves, and light valvetrain is always a good thing. They are probably cheaper too, and OEM componants are made to live a long life.
Old Oct 12, 2002 | 09:00 AM
3rdGteg's Avatar
Default Re: New valves for B16 what would you choose?? (Sonic)
Yeah stock valves
Old Oct 12, 2002 | 09:19 AM
InevitableRace's Avatar
Get these......... Titanium valves also available cost is $90.15 per valve ($1442 complete set, 16 pcs.) Or just go with the Skunk valves
Old Oct 12, 2002 | 11:34 AM
evo's Avatar
evo
New User
Default Re: New valves for B16 what would you choose?? (allmotrb18c1)
Is Shunk 2 racing valves(high compression) lighter and better than ITR valves??
Both of them are about the same price.
ITR valves $310
Shunk 2 $ 350
[Modified by evo, 8:35 PM 10/12/2002]
Old Oct 13, 2002 | 06:32 AM
DonF's Avatar
We have found that the new high comp. REV valve flows a little better than stock, the ex. valve is lighter and we sell them for$288.00
Old Oct 13, 2002 | 11:15 AM
MikeSarr_GSR's Avatar
Default Re: New valves for B16 what would you choose?? (DonF)
make your hp another way. the stock ITR valves on the intake side are a great upgrade, leave the exhaust ones stock. make power from proper tuning and choosing the proper manifolds, etc. stainless steel valves are not good to run in a street car long term since they flatten the valve seat prematurely
Old Oct 13, 2002 | 12:00 PM
miller's Avatar
Default Re: New valves for B16 what would you choose?? (MikeSarr_GSR)
who sells titanium valves???
Old Oct 13, 2002 | 12:27 PM
Tbone's Avatar
Default Re: New valves for B16 what would you choose?? (vtecdoc)
REV racing valves.
Old Oct 13, 2002 | 11:04 PM
Lsos's Avatar
How would titanium valves work? I thought titanium had a problem of "grabbing onto" other metals. How would you keep it from touching other metals in a valve?
Old Oct 14, 2002 | 12:46 AM
evo's Avatar
evo
New User
Default Re: New valves for B16 what would you choose?? (Lsos)
Someone has mentioned if ITR valves on the intake side only will causes unbalance on valvetrain?? is this true?
Old Oct 14, 2002 | 01:33 AM
Drag R's Avatar
whoever told you that is full of ****.....in a type r head, the only valves that are different from b16/gsr are those on the intake side....
nick
Old Oct 14, 2002 | 01:38 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: New valves for B16 what would you choose?? (Drag R)
nick
Yep, Nick is right.
Just replace the intake valves with ITR and call it a day.
There are only a couple of reasons to change your valves:
1- Burned one out.
2- Broke or bent.
3- Going SC/Turbo/NOS (and even then, all you need are SS exhaust valves)
4- Don't care about money, and want to brag.
Old Oct 14, 2002 | 07:38 AM
DonF's Avatar
Default Re: New valves for B16 what would you choose?? (B18C-EJ1)
REV,Ferrera,Crower,and Del West all make titanium valves, they are coated to prevent gualling. ITR valves are 2 piece, the upper 1 inch is a steel alloy and the rest is a stainless alloy, if you have a magnet you can figure it out. Racing stainless valves are 1 piece, some flow better,some flow worse.
Old Oct 14, 2002 | 08:44 AM
tk's Avatar
tk
At least Ferrea valves are severe duty and Crowers are just heavy duty.
Worry free for durability and hi revs and don't want to spend for titainium then Ferrea is the best choice IMO and alot of other top engine builders
P.S Ferrea makes a complete valvetrain kit for v-tecs (double springs,titainium retainers,chromemoly locks,intake and exhaust valve,and shims)
[Modified by tk, 5:47 PM 10/14/2002]
Old Oct 14, 2002 | 12:22 PM
evo's Avatar
evo
New User
Default Re: New valves for B16 what would you choose?? (tk)
[QUOTE] The JUN'3, valve spring, ti-reatiners and CTR piston will install in the B16 at same time.QUOTE]
If I fit the Mugen 0.47mm head gasket to combine with all the parts i've got, is there any clearance issue ??
Old Oct 14, 2002 | 09:19 PM
Lsos's Avatar
Makes sense.
all-mtr-teg
11
May 27, 2008 11:40 AM
PARADOX_sf
Mar 7, 2008 01:37 PM
SoyMilk
10
May 26, 2007 02:13 PM
Allstar
Apr 30, 2002 07:54 PM
