H2b 91 dx
Planning on doing the swap soon. Know it's hard and so on I've search plenty and most peoples only info was a chuckle then "good luck". Just looking for input from someone who has done it before. I know I need mounts, jumper harness with 4 wire o2 and distrib jumper/vtec hook up. I'm just nervous that there's a part of the swap I couldn't find in my research. Other then axles, teggy intermediate shaft,shift linkage,dpfi coversion and a lot of dents cuts into the body is there anything I'm missing? Any help is appreciated or links I could use. Thank you in advance.
alternator relocator , shaving crank pulley or getting single crank pulley, cutting a chunk on the block,balance shaft eliminator, moving 1/2 over , and cutting a big *** hole in your hood
i went h2d in my crx love the power and all but wished that i would have gone built b or something
Thank you. I actually got a list o everything I need and it's finally complete. I was thinkIng of boosting a single instead but to many people said I can't swap a u2. In a ef so let see how it goes
Ryrie1995
Sep 19, 2016 04:31 PM
braass91
May 8, 2008 06:39 AM
hybrid1990crx
Jun 26, 2006 07:22 PM
hybrid1990crx
Jun 26, 2006 08:49 AM
