brakes
we all know when you work an engine you need brakes to stop the extra *** you have found......that said what is a good brand to look for some front rotors for a 96 accors (lx). i found a set of direct replacement brimbo rotors but i cannot find the website i seen them on and it was a nice deal for around 250 but if any of yall out there know where to look for say a complete 4 piston rotor and caliper set please let me know my passenger side caliper is leaking badly around the piston and has alot of play in its housing (even after a rebuild) so its time for something better! thanks for the info
Keep in mind you will probably have to replace your old master cylinder as well - I'd recommend staying with a brand new OEM unit versus a questionable rebuilt one.
thanks muffin man for answering the question. does it matter what year of legend i get the calipers off of? and the reason why im asking about the rotors is because the stock set on the front is getting super hot now with a stock engine so im trying to locate some cross drilled and slotted rotors thanks again mike
You really shouldn't need anything more than Brembo "blank" OE rotors. I would just get them from TireRack. The crossdrilled/slotted thing is kinda silly IMO and unnecessary for street cars. If you do have legitimate heating issues, installing a brake cooling duct would be much more beneficial.
My setup, which would stop on a dime literally:
- NA1 NSX calipers
- '95 Accord Wagon rotors (1" larger in diameter IIRC)
- '95 Accord V6 caliper brackets
- '94-97 Earl's SS brakelines
- '96 new OEM BMC
- ATE SuperBlue fluid
Keep in mind tires are important in braking as well. I had ABS on mine, but the new owner had the ABS go out on him sometime after I sold it. Considering the ABS modulators are kinda known for being bad, I wouldn't attribute it to the upgraded brakes as much as I would age/mileage.
Hondaaccordvtec
Sep 4, 2003 07:24 AM
