1998 Accord Coupe Clutch problem.
Old Apr 6, 2012 | 02:32 AM
tonyasleep's Avatar
Default 1998 Accord Coupe Clutch problem.
Hi there,
I've got a 1998 Accord Coupe 2L.
I have a clutch problem, The clutch peddle depresses but does not return.
I have to hook my foot under the peddle to bring the peddle back up to change gear.
there is fluid in the clutch resevoir and when I had a look at the peddle itself have noticed a loose circlip and unidentified washer type thing on the piston that the peddle pushes into the clutch master cylinder.
Should there be a return spring mechanism on this piston??
What is wrong and what would be the best plan for repair.
many thanks in advance
Tony
Old Apr 6, 2012 | 04:25 AM
jmarshall098's Avatar
Default Re: 1998 Accord Coupe Clutch problem.
It seems that the master cylinder has been damaged, which is why there is no compression in the pedal.
Old Apr 6, 2012 | 07:17 AM
Arthas's Avatar
Had the same problem when bleeding an RSX-S. It was the master cylinder that the clutch depresses. Replaced it and probably was fixed.
Bad part was, it cost like $120.
Old Apr 7, 2012 | 09:04 AM
tonyasleep's Avatar
Many thanks for the advice.
I now have this Accord Coupe (1998) for sale - Spares or repairs as I'm not going to repair it As I have picked up a 2002 Accord saloon for a bargain price.
PM me for details
njmodi
Apr 11, 2012 06:07 AM
ge0rgi0
Jun 19, 2008 09:23 AM
Thrillhouse
Dec 22, 2003 05:06 PM
GSRaCeRbOI
Jun 10, 2002 12:48 PM
integsra
Jun 25, 2001 06:48 AM
