Fully built 84mm Gsr Longblock!
It has barley over 1k miles on it. I have receipts for EVERYTHING!!!*
84mm Gsr*
Ge sleeves*
Arias 9:1 pistons*
Eagle rods
Moroso *oil pan
Polished victor x intake manifold
4bar omni map sensor
70mm omni tb
Itr head mild port job*
Arp main studs
Arp head studs
Acl bearings
Ctr cams
Sk2 pro series cam gears
Super tech valves
Super tech springs
Super tech ti-retainers
Stage 5 completion clutch With flywheel
This setup will easy make over 650. It did make 514 on 18 psi on e85 *I have dyno sheet. I was only on ID 1000s why it only made 514 whp throw some 2000s it will easily make 650+ with the right turbo kit.
I am looking to sell whole engine and everything else I listed for 3,700 I have wayy more than that into it. I will show you all my paper work. I do not mind you going through the engine I have nothing to hide. Only serious buyers though. If you take head off or anything off will be a core charge to replace the gasket.*
84mm Gsr*
Ge sleeves*
Arias 9:1 pistons*
Eagle rods
Moroso *oil pan
70mm omni tb
Arp main studs
Arp head studs
Acl bearings
Ctr cams
Super tech valves
Super tech springs
boosted.si04
Northwest (Sales)
37
Apr 11, 2012 09:38 AM
boosted.si04
Northwest (Sales)
Nov 13, 2011 01:26 PM
