Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Need some advice... 99 TL radiator fan not coming on and car overheats
Old Apr 5, 2012 | 08:20 AM
gotnos2's Avatar
Default Need some advice... 99 TL radiator fan not coming on and car overheats
1999 TL
Already replaced thermostat, and fan switch on thermostat housing.. Still the car gets hot when going low speeds or sitting. I unplugged fan plug and ran 2 wires to pos and neg battery terminals and put in plug to see if fan would turn on but nothing happened. Shouldn't that have turned fan on? I also checked fan fuse under the hood and its good. How do you check a relay or is the problem just the fan itself. Any ideas? Anybody else have this problem?..
Thanks in advance for any help...
Old Apr 5, 2012 | 09:21 AM
gotnos2's Avatar
Default Re: Need some advice... 99 TL radiator fan not coming on and car overheats
Also flushed the radiator several times to get air out and make sure nothing was trapped and put a new radiator cap on.. I was told could be head gasket as well.. hmm..
Old Apr 14, 2012 | 05:00 PM
BAYsikDC4's Avatar
Originally Posted by gotnos2
1999 TL
you have a bad fan motor.
Old May 15, 2012 | 12:19 PM
ZypKode's Avatar
I had my Radiator,Thermostat,Water Pump replaced and a Coolant Flush. The Problem is Gone.Are you using Honda Parts or Aftermarket Parts?
Old May 25, 2012 | 11:23 AM
ht023's Avatar
+1
easy and quick check: have the car running, turn the AC on.
Both Fans on/running?
joelro28
Feb 22, 2014 12:43 PM
fatl13ert
Oct 22, 2012 12:41 AM
nothing_shocking
Mar 10, 2012 11:57 AM
dudeomega2000
Jan 6, 2008 09:51 PM
dragaholic
Jul 29, 2006 11:43 PM
