ride hight problems :?
well got some rokkor coilovers (bad choice in my book) butttt if i got them i might as well ride them out alittle, problem is i set them all the same but the car comes out not even ?! ..this is wat i did i put the adjustable stops things at the bottom then turned it 12 1/2 up put it together and put it on the car and lower it but at the end the car is uneven all different hights ..wat am i doing wrong ?! sorry for the read .. thanks
its a 20+ year old car things distort/move/settle over time could be any number of causes but only one solution decide on the height you want and adjust it accordingly at each wheel
Remember that adjusting one corner of car affects the opposite corner (ie LF + RR,etc...)
Also teh weight of driver once seated! Between each adj,ride around to "settle" teh suspension. (Pros recommend best way is on tiles under all 4 wheels-with salt sprinkled in between them to allow them to "slip" on each other-less "riding around settling" that way),meh I just adjust em as needed since I LOVE driving,lol...
JSITR
Jun 27, 2002 06:57 PM
