Want to Buy Want to Trade/Want to Buy
wtb b-series motor
Old Apr 5, 2012 | 07:06 AM
GSR615's Avatar
Default wtb b-series motor
Long block or short block ...pm me
Need one asap
Old Apr 5, 2012 | 09:29 AM
92CivicSiOEM's Avatar
Default Re: wtb b-series motor
I have a JDM B18C (GSR) with plenty of bolt on parts...still in car running! LMK if interested via PM...
Old Apr 9, 2012 | 09:14 AM
EGcivic_95's Avatar
Ls complete swap pm me for more info in interested
Old Apr 9, 2012 | 12:24 PM
RobVP's Avatar
I've got B20's available
Old Apr 13, 2012 | 06:14 AM
bigg86's Avatar
i got one built
B18B1
- MICRO-POLISHED AND BALANCED HONDA CRANKSHAFT (0.10 UNDER)
- NEW CRANKSHAFT BEARINGS AND THRUST BEARINGS
- NEW FRONT AND REAR MAIN SEALS
- "INLINE 4" NEW SINGLE BELT FORGED ALUMINUM CRANK PULLEY (NOT EBAY CRAP)
- DARTON CAST IRON SLEEVES BORED TO 84MM (2.0L) - over $1k on labor
- BRAND NEW WISECO PISTONS (will disclose compression ratio to BUYER ONLY)
- MODIFIED EAGLE RODS WITH NEW BEARINGS
- APR HEAD STUDS
- NEW OEM WATER PUMP
- NEW MODIFIED OEM OIL PUMP (SHOULD INCREASE PRESSURE BY 20-30%)
- NEW TIMING BELT
- NEW OEM PULLEYS AND TENSIONER
- NEW ALUMINUM OIL PAN WITH OIL RETURN FITTING
pm me if interested
Old Apr 13, 2012 | 06:18 AM
bigg86's Avatar
actually this is what i have for sale....
BLOCK
B18B1
- APR HEAD STUDS
- NEW TIMING BELT
HEAD
- B18A1
- FULL EXTREME PORT & POLISHED JOB ($1500 LABOR)
- NEW FERREA VALVE GUIDES
- THREE ANGLE VALVE JOB
- HIGH FLOW FORGED VALVES, OVERSIZED +1mm INTAKE- +1mm exhaust
- NEW BRIAN CROWER TITANIUM RETAINERS AND DUAL SPRINGS
- BRIAN CROWER STATE 2 BOOST CAMSHAFTS
- STR ADJUSTABLE CAM GEARS
- CHROMED VALVE COVER
INTAKE
- SKUNK 2 PORT & POLISHED INTAKE MANIFOLD (MODIFIED FOR EXTRA VACUUM LINES)
-WILL INCLUDE MAP3 SENSOR
- SKUNK 2 70mm THROTTLE BODY
EXHAUST
- 3 INCH DOWNPIPE (4 BOLT TURBO FLANGE)
- HIGH FLOW CAT
- 3 INCH CATBACK (RESONATED)
CHASSIS
- 95 HONDA CIVIC CX
- INTEGRA GSR LEATHER FRONT SEATS
- CUSTOM REAR LEATHER SEATS TO MATCH FRONT SEATS
- POLYURETHANE FRON LIP
- BUDDY CLUB SIDE SKIRTS AND REAR BUMPER
- FULL ADJUSTABLE COIL OVER KIT
- FRONT SKUNK 2 ADJUSTABLE CAMBER KIT
- REAR ADJUSTABLE CAMBER KIT
- REAR BRAKE DISK CONVERSION
- NEW PADS AND ROTORS
- MID AND UPPER JDM WINGS
- NEW FRONT WHEEL BEARINGS
- NEW FRONT TIE RODS
- NEW FRONT UPPER AND LOWER BALL JOINTS
FUEL SYSTEM
- WALBRO 255LPH FUEL PUMP
- AEROMOTIVE HIGH FLOW FUEL FILTER
- AEROMOTIVE FUEL PRESSURE REGULATOR WITH GAUGE
- AEM FUEL RAIL
- 880cc INJECTORS
TRANSMISSION
-B18C
- NEW CUSTCO LSD
- REPLACED ALL BEARINGS AND SEALS
- SKUNK 2 SHORT SHIFTER AND SHIFT ****
- AI4-XXG6 ACT CLUTCH KIT (TORQUE: 486 FT/LBS) LOAD CLAMP INCREASE OVER 145%
- 8LBS FIDANZA ALUMINUM FLYWHEEL
TURBO PARTS
- HORN STYLE EXHAUST MANIFOLD (MODIFIED TO FIT T03/T04 AND T4 TURBOS)
- NEW TIAL 44mm WASTEGATE
- 32 X 12 X 3 FRONT MOUNT INTERCOOLER WITH COMPLETE PIPING
- BLOW-OFF VALVE
Old Apr 13, 2012 | 06:20 AM
CHEETAH's Avatar
i got a b16a turbo block with ported head..even have a turbo kit too for it
Old May 27, 2012 | 12:41 AM
Thmanx's Avatar
My setup is also up. Its a B16A2 was used for smog/state ref.
Comes with a verity of goodies inside, check it out.
Its available w/ shipping & Flexible payment plans if needed.
http://hondamarketplace.com/showthre...3#post47343663
Old May 30, 2012 | 08:26 AM
0_o1TiMeXx's Avatar
still looking? i have a b16a2 long block. just want it gone. offer
jdmdelsol51
Apr 13, 2012 10:08 PM
2literCR-X
Feb 1, 2009 12:38 PM
m R g S r
Dec 18, 2005 09:54 PM
X-Mazda 3 Racer
Mar 25, 2005 01:31 PM
