JDM EF7 calipers?
Old Apr 5, 2012 | 06:43 AM
LoveDeezNutz's Avatar
Default JDM EF7 calipers?
Is there an identifying number somewhere on a caliper? I have a 88 JDM EF7 and may need to replace a piston seal, plus I think it would be something good for me to know so I dont order the wrong parts again.
I called Honda to order new brake hoses and was met with the word I hear more and more "Discontinued" so I ordered some after market ones from passwordjdm. I spoke with a guy who had an EF7 as well and asked him about the brake pads which he said are the same as a DA.
So my question is if the caliper itself is from a DA?
I cannot locate anything that gives an in depth faq about what parts on a crx are on a different car.
If it is true the entire brake setup is DA and the ZC engine is the same for an 88 Integra should I be under the impression that all mechanical related things are from an integra?
Old Apr 5, 2012 | 07:12 AM
crx_si-r's Avatar
Default Re: JDM EF7 calipers?
For one a DA is not the same as a 88 integra.
Do this. Take the original brake pads from the EF7 in to any autoparts store and have them match the pads. Do your current calipers have a mounting bracket? Or do the mount directly to the knuckle?
Old Apr 5, 2012 | 03:27 PM
Deetz's Avatar
Crazy Honda Guy
To add to what crx si-r said, a DA is a 90-93 Integra, very different car than the previous generation
Old Apr 6, 2012 | 06:39 AM
Thank you, its why I started saying integra towards the end and not DA. When I had the gaskets replaced on the engine the part was ordered from an 88 Integra. The passwordjdm guy said DA for the brake pads. I have googled this and did find a guy who asked the same question several years ago but no one was able to answer his question.
I received my brake pads for a USDM 88 CRX si yesterday. I will be able to compare the brake size and if not take it to autozone for a match, but since I need to find new caliper parts I need to know what I am looking for.
I do not know the answer to the previous question about the knuckle since I only took the pad out to inspect it.
I will try to get pictures over the weekend since it will actually be sunny.
Thank you again
Old Apr 7, 2012 | 05:06 PM
Here are pictures. I am not sure how much calipers vary in appearance, but at this point, I feel SOL. I am hoping here is someone who has read nothing but honda manuals his/her entire life.
I went to god knows how many auto stores today to try and match up the brake.
I would list every honda and acura car I asked them to compare my trace to, but I asked so many I dont even remember going to various stores. I believe I do have some hope though, but I will have to call EBC on Monday to see if there product codes vary from region.
Which brings me to the only hope I have besides just having new calipers put.
There is a code (16cl13vn) on the caliper which when googled says 90-91 crx si.
EBC brakes (which I currently have on it). Have no code, but when I went to their website and searched EF7, some japan catalog spreadsheet came up. I found EF7 looked at the green stuff brake code. went back to the site and searched for "DP2706" a ton of spreadsheets came up, clicked the american one and it says its same on various other cars: Preludes, integras, civics, sedans and crxs.
However I know for a fact that I probably have asked most if not at least one year and model at one of the many auto part stores I went to and none of the brake pads matched up.
Anyway head hurts. Thank you.
Old Apr 8, 2012 | 08:29 PM
~sp33~'s Avatar
EFB055
Have you tried just bolting on a different caliper?
I would put money on the US caliper bolting straight onto your spindle.
Old Apr 8, 2012 | 09:52 PM
tonylovesjdmEF9's Avatar
88-89 integra is a da but its a da3
everything you have there is a da caliper and da rotor...friend had same set up
Old Apr 9, 2012 | 11:18 AM
Ok I have a follow up dumb question. Because I looked at several brake pads. I will most likely switch to a USDM caliper eventually, but for now my question is brake pad and caliper related.
1. When I do a search for 91 crx si or an integra brake pad the pattern does not ALWAYS (some sites actually show the same pattern) even though its for the same car and year. Is this normal? I dont really want to buy a pair just to see if one without the same pattern fits. I just find this really strange that they would have 2 patterns for the same year and model.
2. If I do find the brake pads I need and do a reverse look it up is there a 100% chance that that is the same caliper? meaning if you have 1 caliper you cant just swap in a different brake pad?
And for the above poster, so your friend ordered caliper parts for a DA or a DA3?
Hopefully I dont run into discontinued when I call for the part number.
Old Apr 9, 2012 | 11:30 AM
da3 is the older model of integras you need to order parts for the 90-93 integra as far as brakes goes....unfortunatly honda/ acura have stop producing most parts for the efs and DAs
Old May 6, 2012 | 05:19 PM
Vagitarian's Avatar
So my 1989 Ef7 Crx has 4 wheel disc brakes. The front would be 90-93 integra rotors and pads?? What about the rears?
Old May 6, 2012 | 05:49 PM
rallypoint_1's Avatar
I am running 90-93 integra calipers. The caliper number is a little different.
The number is 17CL14VN
Old May 6, 2012 | 07:11 PM
Vagitarian's Avatar
but the oem ef7 calipers use which rotor and pad?
Trying to find parts here in the states
Old May 6, 2012 | 08:37 PM
the DR.'s Avatar
Don't think anyone answered the original questions, so here goes..
The calipers you have are the same as 90-91 CRX Si (I have these calipers and the stamped number is exactly the same.) The pad/backing plate outline you have is D373, you should be able to cross reference that same number with most brake pad manufacturers. HTH
Old May 7, 2012 | 08:52 AM
Vagitarian's Avatar
So I can buy brakes from an 90-91 Crx Si.
You seem to be sure on the stamped number correlation for the FRONT brakes, but are the rears also the same?? I noticed the caliper is much smaller.
I can go to my shop and take the wheels off and get any pics of anything you need if it will help me sort out which car I need to buy brakes for.
Thanks so much
Old May 7, 2012 | 05:02 PM
the DR.'s Avatar
Thanks so much
I checked my rear calipers (90 CRX Si), and the number stamped on them is 7CLP13S. The pad/backing plate number for the rear pads are D374. The D374 pad is actually used on many Civics and Integras (except ITR) The rotor diameter is ~24cm/9.45in.
If you can verify this info is the same on your car, you should be able to order these brake parts using 90-91 CRX Si as reference.
Old May 7, 2012 | 10:27 PM
Vagitarian's Avatar
Im going to go pull my rear ties off right now and try and find some numbers on these rusty things. Thanks so much!!
If I understand what youre saying though, I can simply order 90-91 crx si front and rear brakes, both pads and rotors.
Alot simpler than I thought
Old May 7, 2012 | 10:40 PM
chargeR's Avatar
This man is correct, don't know what the others were talking about. An EF7 brake setup is the same as an ED9. 242mm front rotors with the same calipers as your locally delivered 90-91 CR-X Si, so anything you get for an 90-91 Si should fit fine.
DA9 stuff is the same as EF8 not EF7. DA6 (JDM XSi) is different again I believe.
Old May 8, 2012 | 10:51 AM
Vagitarian's Avatar
And the rear is the same as usdm Crx Si?
Old May 8, 2012 | 10:54 AM
Vagitarian's Avatar
edit: typo
Old May 9, 2012 | 01:08 AM
Vagitarian's Avatar
I checked my rear calipers (90 CRX Si), and the number stamped on them is 17CLP13S. The pad/backing plate number for the rear pads are D374. The D374 pad is actually used on many Civics and Integras (except ITR) The rotor diameter is ~24cm/9.45in.
thank you again, I found the time after work to get to my garage and pull the wheel off and take a pic of my rear caliper
Only difference is there is a 1 infront of your serial stamp while the rest of the code is the same, will this be of any difference??
Old May 9, 2012 | 03:45 AM
chargeR's Avatar
It should be the same as the 90-91 US model CR-X rear yes, as far as I know all the EF/ED/EE CR-X rear disc setups were the same. At least the rear brakes on my EF8 are the same as the ones on my ED9 and pads for a US Si fit my EF8 at the rear.
Old May 9, 2012 | 09:38 AM
the DR.'s Avatar
Sorry that extra 1 was a typo. So you have the same calipers 7CLP13S
mattp27
Oct 13, 2013 09:48 PM
EGfosho
Suspension & Brakes
Oct 6, 2009 05:13 AM
choboco87
Jun 11, 2009 08:24 PM
HondaFerris
Sep 12, 2007 05:02 AM
Johnny_bdos
Apr 19, 2002 04:37 PM
