Cam broke now time for MPFI swap
Old Apr 4, 2012 | 07:30 PM
CivicxTree754's Avatar
Photogenic
Loved
Default Cam broke now time for MPFI swap
SO i was driving on the highway and started loosing power. My oil light was only coming on during really hard turn so I thought I had some time like a few days till payday to do the oil change. Apparently not. I think the head starved of oil and the cam just snapped from the sprocket.
After preping for mpfi swap and new head I decided to see the damage extent and maybe I could just swap the cams but some of the teeth on the belt are gone, and the seat for the cam at the sprocket side has a ugly downward lip now and bad groove marks in it. See the damage below.
So I got a decent looking head which I plan to get milled about .040 and do the MPFI swap. I have a harness from a previous build but some parts are missing but its enough to do it.
I am reading because this will be my first MPFI swap. Im reading alot of articales some arent as clear as others. Here are a few im reading over after searching.....
http://hondaswap.com/swap-articles/d...writeup-49557/
http://www.civic4g.com/index.php?opt...pic.php&t=9737
Anyone have any other threads to suggest that may be clear'er with more detailed pictures or diagrams? Thanks And do I need the resistor box? I have a 91 dx.
Old Apr 4, 2012 | 08:00 PM
ricernick93's Avatar
Default Re: Cam broke now time for MPFI swap
You wont need a resistor box if you use obd1 injectors. If you got a a6 complete IM then all you should have to do is wiring. What head did you buy?
Old Apr 4, 2012 | 08:35 PM
Photogenic
Loved
Heres a pic of the head and the IM. The seller was from here he said the dizzy he included was from a d15b7 obd1.
I think I have 4 injectors from my a6 or z6 that i had a while ago. Ill check them out and post any numbers I find, on here.
Old Apr 4, 2012 | 10:27 PM
///Mathew's Avatar
I just have one suggestion. If your oil light EVER comes on, even "during really hard turn", put a quart of oil (probably two) in that **** ASAP. Like pull over and do it right now. Never mind waiting a few days for payday and an oil change.
Old Apr 4, 2012 | 11:58 PM
DCRB's Avatar
Seriously!!! i check my oil every time i tank up, and atleast once in between then. if you're about to change it then just buy the cheap 76 buck 99 stuff
Old Apr 5, 2012 | 02:13 AM
Spug's Avatar
If the camshaft stopped, but the crank didn't (which happened, since you were moving when the cam stopped), you're probably going to need more than just a head. You could very well have damaged some pistons when they contacted the valves.
nominous
Dec 12, 2008 09:53 AM
HONDATUNER356
Jul 17, 2006 01:56 PM
hybrid1990crx
Jul 22, 2005 09:39 PM
user 98292739
Apr 2, 2005 02:42 PM
972drcordex
Jan 11, 2004 02:12 PM
