Coolant temp rises at idle.....94 4cyl...among other issues
Old Apr 4, 2012 | 06:33 PM
Rein4st's Avatar
Default Coolant temp rises at idle.....94 4cyl...among other issues
I noticed lately, my coolant temp rises at idle....after coming to a stop.
Immediately after throttle up, the temp quickly drops. If it was an american car, I'd suspect a fan clutch.
Another thing I noticed about this car, is the heater sucks....luke warm at best.
The coolant fan comes on after key is turned off.....normal ??
Any idears ??
Old Apr 4, 2012 | 06:40 PM
Rein4st's Avatar
Default Re: Coolant temp rises at idle.....94 4cyl...among other issues
Could the water pump vanes be worn ??
I would like to get this resolved before summer hits ....
Old Apr 4, 2012 | 07:39 PM
invader_zim's Avatar
Is the car topped off with coolant? The temp dropping as you go, luke warm heater and fan issue sounds like you're low on coolant. The same things happen to my wagon when I had a slow leak and the level got low.
Old Apr 7, 2012 | 06:44 AM
Lost Again's Avatar
On the t-stat housing (lower hose connects to engine) there is a green two wire connector. Remove the connector and use a paperclip or something to connect the two WIRES together, turn the key to on/pos II.....do BOTH fans come on?
Old Apr 7, 2012 | 11:17 AM
nus_dogg's Avatar
Mine does the same thing when I sit at idle for more than 5 mins after it has been running hot. When jump the radiator fan switch connector, it kicks the radiator fan on meaning the whole circuit is working, so only thing I needed to test now is the radiator fan switch itself. Still need to test that as for me.
dhonda00
Jun 11, 2013 04:14 PM
civicsirebuild
Dec 20, 2010 10:13 AM
vlude99
Jul 30, 2009 05:58 PM
hotcivicsi
11
Apr 9, 2009 06:19 PM
9K
Jan 7, 2002 05:16 PM
