FCS Fluid Containment Device (Engine Diaper) IN STOCK @ Xenocron
http://www.xenocron.com/fcs-fwd-engi...ice-p-754.html
We received our shipment of FCS Engine Containment Devices today which is the latest and greatest NHRA approved and recommended device for the Sport Compact FWD Drag Racers out there.
Many event organizers are already requiring some sort of containment device for heads up classes and this is simply the easiest device to use, install and uninstall for track use...and its affordable too.
If you are attending Honda Day this year or any of the other OGS events in the Northeast, check the class rules and make sure if you need something like this for the particular class you wish to run.
Even if it isnt required for your class, its just good manors to make sure you arent the one who might possibly oil down the track if engine or tranny failure happens to you.
Lo-Buck EF
35
Dec 23, 2002 05:37 PM
