Trans/ Clutch acting up. Please help
So this just happened not 30 minutes ago. I'm driving home and my car starts grinding in every gear, then 5 mins later it's not letting me go into some gears. It's really weird that this came out of nowhere. It's almost like the clutch isn't fully engaging and the reason I say this is because if it is in gear and I have the clutch fully compressed, the car does that skiping like I'm letting off the clutch without giving it enough fuel. Anyone with any insight would be greatly appreciated.
Does your clutch pedal feel as firm as it usually does? or does it spring back up quickly? ---possible leak in the clutchline or master or slave cylinder...check your clutch fluid to see if it is empty. if empty, then fill, bleed, and have someone pump the clutch while u check for leaks in the system.
and yes, you are thinking well.....if you are stopped, clutch pushed down, and it feels like it is trying to engage,....that is why i suspect the low clutch fluid pressure.
supercivicstack
Sep 12, 2009 02:24 PM
range
Dec 1, 2003 02:01 AM
