DIY: EG/EJ sideskirt removal
Old Apr 4, 2012 | 01:46 PM
Blacknight117's Avatar
Icon6 DIY: EG/EJ sideskirt removal
So, my first write up on something that I know a few people have asked about in the past. Removing the sideskirts from an eg or an ej is pretty simple. So, here goes...
What you`ll need:
Phillips head screw driver
A bit of time
Before you remove the skirt, you have to remove the mudflap, if applicable. (If you have the flaps, there will be four screws that you have to remove).
After that, on the underside of the skirt, there will be 7 or 8 what I call ufo clips that must be removed. As you can see, all you need to use is a phillips head screw driver to remove them. Unscrew them and they should pop out.
After they are removed, all you have to do is slide the skirt foward. It will take a little time, but it will come off. Here is what is should look like after you get it off. If you break one, don`t freak out, the skirt will stay put. But if you do happen to break a clip, the part number is: 91513-SM4-000-Honda #35, from Honda Parts Unlimited.
And that`s pretty much it. Installation is the same as removal.
The one thing that I found that made it easy to put the clips onto te skirt itself before you put it back on. Than all you have to do is push the skirt onto the car.
Old Apr 4, 2012 | 09:32 PM
crzdmngz's Avatar
Default Re: DIY: EG/EJ sideskirt removal
nice diy!
Old Apr 4, 2012 | 09:47 PM
Yo Pintura Trenes's Avatar
My favorite part is kicking them off especially when a forklift is holding the car up for me. Makes it really interesting!
Old Apr 5, 2012 | 04:56 AM
yeahsmitty's Avatar
this was hella helpful!
Old Apr 5, 2012 | 06:41 AM
Originally Posted by crzdmngz
nice diy!
Thanks
Gald I could help
SLeePeR-STaTuS
Apr 1, 2008 05:39 PM
RED95EG6
Aug 3, 2007 06:15 PM
revlimitcrx
Welding / Fabrication
Dec 12, 2006 04:43 PM
RICE POLICE SIP
Jun 23, 2003 05:24 PM
viprcr1
Jun 14, 2003 11:19 AM
