highlight relay location
Yes there is a relay. You should download a factory service manual, they are free on a few sites. Also, they are called high beams. Highlights go in your girlfriends hair. You might have better luck searching when you use the right words.
look on the passenger side right behind the headlights. you should see 2 white plugs plugged into 2 relays. That's where mine are on my 88.
