Ccw classic wheel spec help for eg
Old Apr 4, 2012 | 09:52 AM
eg:R's Avatar
Default Ccw classic wheel spec help for eg
Thinking about ordering these new for my dd. I notice now that u can order custom spec now compare to before. Planning to order 16" street version, but I'm not sure on how wide, Lip size and off set. Planning to put this on my eg civic. I'm planning to run 225's in front and 205's in rear if that help. Why I'm running wider in front due to trying to get the most traction from my turbo eg.
Can weld magnum drag rims get warp from driving it on the street? Cause I have street slick in front and mt in rears. Sum guy have stop me and said my rims can get warp from driving on the street. This is only a weekend car. Is this true? If so then I'm looking to to get a set of ccw classic. I like the lip look from the welds.
Old Apr 4, 2012 | 07:44 PM
toyomatt84's Avatar
Sanji
Default Re: Ccw classic wheel spec help for eg
When you ordered your Weld wheels, did you ask/request a safety bead to be formed in to the barrels? If so, then you should have no problem running them on the street. If not, you may want to inspect the wheels for the bead.
Old Apr 6, 2012 | 09:30 AM
eg:R's Avatar
Idk, I bought them used and they already came With the street slicks. Can I found out without the tires being off?
sleepy_hatch
Jan 5, 2012 10:02 PM
jdmcx
Aug 19, 2011 10:20 PM
CRXEE8
Oct 9, 2005 10:58 AM
