Forgot to add liquid gasket to new valve cover gasket
Old Apr 3, 2012 | 02:23 PM
davidt1's Avatar
Default Forgot to add liquid gasket to new valve cover gasket
Car: 94 Honda accord
Problem: I just replaced the valve cover gasket, but forgot to add liquid gasket to the new gasket, as specified in Honda manual. I don't want to do it again. Is this absolutely critical? Thanks.
Old Apr 3, 2012 | 02:26 PM
DELshaneSOL's Avatar
Default Re: Forgot to add liquid gasket to new valve cover gasket
You don't have to do it again
Old Apr 3, 2012 | 02:42 PM
hondamark35's Avatar
you'll find out if oil starts to seep out through these areas. pull it off and redo it. it's not hard, 10 minutes and you're done.
Old Apr 3, 2012 | 06:44 PM
gesford's Avatar
I wouldn't do it unless it leaks. You might get lucky and not have a problem
Old Apr 3, 2012 | 10:03 PM
Arthas's Avatar
I never added Hondabond to any of my gasket replacements and I didnt get a leak.
Old Apr 4, 2012 | 04:33 AM
gesford's Avatar
Did you use any kind of silicon?
Old Apr 4, 2012 | 05:11 AM
davidt1's Avatar
No, I didn't.
Thanks everyone for the help. I have decided to leave it alone since there is no leak.
Old Apr 4, 2012 | 06:44 AM
GhostAccord's Avatar
That you can see! There are only 4 spots on the gasket that require a dab of HB or RTV sealant. They are the bottom corners where the gasket goes over the cam caps. Unless you remove the timing cover you can't see that area on the gear side. On the distributor end you will be able to see if it starts to leak. I agree that if it's not leaking, leave it.
Just make sure to keep an eye out for leaks behind the distributor and around the valve cover/timing cover on the gear end.
caliskier
Mar 22, 2009 04:45 PM
touandcim
13
Dec 29, 2007 09:46 AM
BlueLude84
Feb 4, 2007 11:14 AM
RicedREX
Feb 9, 2003 09:31 AM
