Wiring Issues
Old Apr 3, 2012 | 08:27 AM
allenlavoie's Avatar
Default Wiring Issues
OK doing my first swap. The car was a dpfi 88 hatch. It has a mine me z6 with turbo. I was having trouble with no power but turned out to be the thermo ground. Fixed it but when I put power to it I seen smoke and smelled wire burning. I use obd1 inj so no res box but I wired the inj to the yellow wires off my factory harness Andi know that was wrong now. But the problem now is I have no power and no dash light. The check engine light and brake light dowdy come on like before. Did I fry my ecu?
Old Apr 3, 2012 | 10:47 AM
91 EF DX's Avatar
Default Re: Need help
probly shorted a hot wire some where under the dash
Old Apr 3, 2012 | 11:15 AM
Aesthetic Gains's Avatar
Dos Pupusas
Does the ecu light stay on at all times?
Can you hear the fuel pump priming at all?
If not, try using a different ECU.
Old Apr 3, 2012 | 11:41 AM
Its a chipped ecu. I dont think there is a light on the ecu. Any ideas what wire in dash I could have shortted out?
Old Apr 3, 2012 | 04:35 PM
Perfectionist's Avatar
Look for the blackened crispy one.
Old Apr 3, 2012 | 05:12 PM
CRX Toad's Avatar
Default Re: Wiring Issues
Please make sure your titles are specific..."need help" doesn't help anyone in the future that may have the same issue. Thank You
Old Apr 3, 2012 | 05:31 PM
91EFH22's Avatar
Basically you fried a wire and are now looking for a needle in a hay stack. You could continuity test the Hot wires and see if anything has continuity to ground. Its a start
DA_Boy_626
Feb 22, 2012 10:37 AM
TekBuDDy
Feb 14, 2007 10:41 AM
Racersky
Audio / Security / Video
Nov 19, 2005 09:36 PM
coot_er
Sep 12, 2004 08:27 PM
rafimos
Nov 5, 2002 09:01 PM
