91 Accord EX F22A4 Electrical issues, No Start
Old Apr 3, 2012 | 07:16 AM
shizoma's Avatar
Default 91 Accord EX F22A4 Electrical issues, No Start
I have a 91 accord ex and have recently done a rebuild on the vehicle, I have put it back together have checked every component that I know of, the ECM was bad and I replaced it, fuel pressure good, good spark, timing is on, check cont at the ignition switch good, checked the relay good, hot at injectors, injectors pulse when cranking according to the test light, ground at t stat is on, however when turning key on the relay does not prime the pump for 2 seconds (but energizes pump while cranking) and I noticed when doing my voltage test on the ignition switch harness at the fuse box, when probing ign 2 I believe, I could hear the relay cutting in and out if I would press on the pin in a certain way. I checked for cont across the inj while cranking but didn't seem to have cont, which I found weird because I have voltage and they pulse to ground when cranking, I am seriously about to pull my hair out....and I thank anyone for any of their advice. I might add that I have a blinking S light when cranking no CEL codes and I did look in the trans unit and there was no connectors resistors or transistors that appeared or smelled like they were blown however I know it is still a possibility.
Old Apr 3, 2012 | 02:26 PM
davidt1's Avatar
Default Re: 91 Accord EX F22A4 Electrical issues, No Start
If you suspect a bad relay, bypass the relay and see what happens.
Old Apr 3, 2012 | 03:45 PM
shizoma's Avatar
Already tested the relay it is good
K00lGuy
Jan 14, 2016 10:49 AM
SergioE92
Jul 22, 2013 12:32 PM
jdmyelloweg
Feb 22, 2011 05:10 PM
404notfound
Dec 5, 2010 10:59 AM
