90 Integra Clutch Installed Into 95 Tranny
So I recently found out that it is NOT a good idea to take a 90 Integra Clutch and Install it into a 95 Integra. The clutch was orginially for a CABLE Tranny and now was installed into my GSR HYDRO Tranny. I recently got alot of GRINDING/CHATTERING and POPPING OUT of Gears. Is my GSR Tranny GARBAGE now? Also what about my STAGE 1 Clutch?
if it was a clutch made for the small spline cable trannys then idk who the hell adviced u to put it on!. take the tranny off and see whats up.. might get away with just changing the clutch plate
TBH, i really don't think it's even possible. 90/91 input shaft is a 24 spline count and smaller diameter. 92-01 is a 26 count w/larger diameter. not only is the size different, the number of splines is different. it physically would not go.
i just can not see anyone even attempting to make that work.
