K series injectors in h series?
I was wondering. will k series injectors fit an h series with aftermarket golden eagle fuel rail? i've read they will work on b series with different o rings and such. and obviously injector clips. i just want to know for sure. also if B and H series are the same?
So, my h22a was in my 94 accord, I've taken the engine and harness out to put in my eg hatch.. what are the chances my injectors will work for the eg? Or is it set in stone I'll need the resister box?
I've searched and searched, found many diff answers and none too complete of an answer... Hoping for some info
What brand injectors? Are they high or low impedance? As an example on my Lancer Evo, it came with low impedance injectors with a resistor pack from the factory. When I switched over to high impedance injectors, I had to cut the resistor pack off and connect the wires together.
