5 Lug Rotors
I find it hard to believe that there aren't front rotors that will just bolt on without having to change all those parts, spend all that money and do all that work.
Thank you anyway.
Thank you anyway.
The rotors don't hold the lug studs; the spindle/hub does. That means you need a spindle that is 5 lug, a bearing that works with the spindle and knuckle, and of course 5 lug rotors.
There is a link to the 5 lug swap in the sticky that tells you exactly what you need. I believe it is the one that Bird333 was nice enough to find for you.
When you find a 5 lug hub that fits into place with the stock knuckle, bearing and rotor (4 lug). Please be sure to let the rest of us know!
Have you ever changed the rotors on your car before? I'm guessing that you have not!
ECKOTYPER
May 12, 2004 09:09 PM
