help me out im in final stage
ok i went to start for the first time iv done a y8head on a a6 block i converted to odb1 dizzy ecu and done mpfi conversion i get spark but car doesnt turn over what could be the problem oh and i have a chipped p06
now im gettin fuel buh idk how to test injectors im using a test light and power comes from neg side but not side from ecu...i appreciate any help
also you can have someone crank while you spray a little efi throttle body cleaner into the throttle body. It is dangerous to your eyebrows bout you can diagnose if your car only needs fuel.
k it back fired once and timing is right piston#1 is at tdc wit up mark on camgear..also where do u wire the yellow/blk wires from injectors? i did research and it say wire to a15 on ecu but a15 on p06 is a/c clutch switch
The YEL/BLK wires to the injectors are the battery voltage source. There should be a junction box with a couple YEL/BLK wires coming from it in the engine bay. It is the same source that feeds the O2 sensor, IACV and the main relay. The OBD1 ECU pins that feed this junction point are A25 and B1.
