doorlocks and power windows don't work
Out of no where my driver's side rear window and door locks stopped working in my 95 sedan. All other doors work fine, I literally went over a speed bump and they stopped working. I've took the door panel off and pulled back the rubber boot to where the door harness connects and I couldn't find any damaged wires or anything. I can't for the life of me find a wiring diagram for this door so if anyone knows of where one is please let me know.
Double check the connectors to the main switch. Before you hit the bump, did the windows open at normal speed or slow and stop mid way? If it was the latter, the switch could be bad. Are the other doors and windows working as they should?
The main plug for power locks and windows are on one switch. This is located in the door near the lock actuator. The ends connect to the driver side power switch. I have not removed the entire door wire harness so I can't tell you which individual wire goes where. If you know someone who has the same model as you, you could borrow their driver side door switch and plug it in to see if it functions.
The window used to work at normal speed, all my other windows kind of struggle on the way back up. The window doesn't work on the main switch, or the switch that's on that particular door. And my front passenger window doesn't work on the driver's side switch, but it works just fine on the passenger side switch. I'm going to the junk yard tomorrow so I'll pick up another switch and see if that does the trick. Until then if anyone has any more ideas bring em on!
Rayz_Si
Apr 21, 2008 06:17 PM
gribbs
Apr 11, 2003 04:52 AM
