92 gsr passanger motor mount removal.
Old Apr 1, 2012 | 10:59 AM
ZombiePharoh's Avatar
Default 92 gsr passanger motor mount removal.
how do you get that mount out? new hasport mount has three holes, two on one side one on the other. and i can only see two bolts holding the mount to the trans. how do i get to that third bolt??
Old Apr 2, 2012 | 11:36 AM
Hasport's Avatar
Default Re: 92 gsr passanger motor mount removal.
you have to take the black bracket off the transmission as well
the one bolt you will need to get at from the bottom
Old Apr 3, 2012 | 06:01 AM
im thinking that this trans is not a real ys1, the mount hasport gave me doesnt bolt up at all. ill post pics when i get off work.
Old Apr 3, 2012 | 09:39 AM
Hasport's Avatar
all 90-93 cable transmissions are physically the same on the outside dimensions
pictures will help
Old Apr 3, 2012 | 12:50 PM
Im pretty sure that i have to remove the plate under the stock mount and that the hasport bolts right on the trans. thats the only was i can think of it lining up, im uploading pics
Old Apr 3, 2012 | 12:57 PM
Old Apr 3, 2012 | 01:30 PM
str84sfed's Avatar
when i bought the hasport cable to hydro conversion i had to remove the plate from the tranny to bolt it up.
Old Apr 3, 2012 | 01:52 PM
this is just a cable trans. guessing the plate "delete" is necessary.
Old Apr 3, 2012 | 02:07 PM
str84sfed's Avatar
from your pics above it looks like it would bolt right up without the plate.
Old Apr 4, 2012 | 03:22 PM
Hasport's Avatar
all correct. you have to unbolt the black bracket on top of the transmission and then the hasport mount will bolt on
Old Apr 4, 2012 | 04:30 PM
thanks hasport! i was wondering if i'd get a reply from you on here heheh.
My 93 accord
May 12, 2016 11:10 PM
scubacamper
Jul 4, 2015 10:29 PM
2k3s2k
14
Feb 14, 2014 01:31 PM
lilo_goki
Jan 5, 2011 08:36 PM
lude98SH
Sep 1, 2007 05:45 AM
